How do i tell if i have a LSD dana 80?
Old Jun 12, 2006 | 01:23 AM
GR40RCapri's Avatar
Question How do i tell if i have a LSD dana 80?
It seems to me, with 118k on the truck, it's either WORN OUT BAD, or it's an open (that would be sucky..)
if i turn one wheel slowly, the other wheel will follow in the same direction, or sometimes not at all...i know usually an open diff turns them opposite, correct?
i took the #'s off the tag..
52070235
3 54 605792
i know the 3.54 part, and the 605792 means it's a Dana 80 from a 96 1/2 2500 ( i looked it up at DANA.com ..build sheet)
any thoughts? if not, i guess i'll have to crack into the case, and maybe get lucky and order me up some clutches.
thanks in advance!
J
Old Jun 12, 2006 | 09:12 AM
Dshiftff's Avatar
Check the tag on the underside of the hood near the latch. Should tell you anti-spin or not. PS I think 94-95 2500 manuals have 80's and 96+ 3500's only have them. Dosent say in your sig what you have...
Jim
Old Jun 12, 2006 | 11:05 AM
Baja's Avatar
Another way is to take your VIN#, call the dealer, they will be able to tell you.
Old Jun 12, 2006 | 12:16 PM
GR40RCapri's Avatar
Jim
it's an 80...all manual trucks have 80's auto's have 70's...
duallys are all 80's..
J
Old Jun 12, 2006 | 01:11 PM
RowJ's Avatar
OR...go to dealer...with VIN # and ask for a "Build Sheet". It's free and will list all options on your truck, as it came from the factory.
Good Luck
RJ
Old Jun 12, 2006 | 01:38 PM
Andy505's Avatar
J
I second that.
Old Jun 15, 2006 | 12:59 PM
GR40RCapri's Avatar
Good Luck
RJ
cool...
that sounds like a plan...thanks!!!
J
Old Jun 19, 2006 | 09:14 PM
cody@nl'sCTD's Avatar
manuals have 80's, auto 70's and 3500= 80's
mudwisr2
Jan 10, 2009 08:33 AM
Common
Apr 7, 2008 08:30 AM
mercury0_0
Nov 4, 2007 08:12 PM
amartinson
Dec 10, 2004 04:04 PM
