Sponsored by:
Sponsored by: CARiD
Dana 80 LSD re-stack
Old Jan 8, 2009 | 10:06 PM
mudwisr2's Avatar
Does anyone have a link or write up on re-stacking or replacing the clutches in the Dana 80 limited slip? I can't seem to have any luck finding something.
Thanks
Old Jan 9, 2009 | 12:33 AM
johnh's Avatar
i replaced mine not too long ago, the new ones come stacked right, if you need more info pm me and i'll try to help... i have a shop manual
Old Jan 9, 2009 | 11:48 AM
Mcmopar's Avatar
I don't think the manual spells it out does it?
Old Jan 9, 2009 | 08:45 PM
mudwisr2's Avatar
Do you have to mess with the ring and pinion and reset the "mesh" or is it pretty easy to do?
Old Jan 10, 2009 | 01:04 AM
HRDROKN's Avatar
Fairly easy rebuild..... keep tabs of the carrier shims, mark the LSD case halves to each other and the cross pins, be sure to soak the discs in gear oil for at least 24 hrs. This proccess should not effect lash, unless it just wasn't right in the first place. Fill with Amsoil 140 and run it!
Old Jan 10, 2009 | 08:33 AM
mudwisr2's Avatar
Whats the purpose of soaking the discs for that long?
Common
Apr 7, 2008 08:30 AM
GR40RCapri
Jun 19, 2006 09:14 PM
amartinson
Dec 10, 2004 04:04 PM
