Hard starting after stall
Old Aug 24, 2005 | 02:33 PM
Sawyer1's Avatar
Angry Hard starting after stall
A couple of weeks ago I was backing the 5er into the driveway through a bit of a dip and the engine stalled. I pushed in the clutch and restarted it with my foot on the throttle a bit and now ever since then it is hard to start unless I give it a bit of throttle then it fires right up.
Any ideas on what the problem could be? It is a 1998 3500 dodge with stock 5.9 12v.
Thanks for any and all answers.
Old Aug 24, 2005 | 03:28 PM
BBWD's Avatar
What is your idle RPM with the AC turned on???
John (DH)
Old Aug 24, 2005 | 03:36 PM
Sawyer1's Avatar
John (DH)
The idle is around 750rpm. If I start it without touching the throttle it sits at about 650rpm until it warms up a bit.
Old Aug 24, 2005 | 04:41 PM
BBWD's Avatar
You may want to bump it up about 100 RPM to about 850. This will make starting easier also. If you will do a search here you can find the instructions and a diagram of where this adjustmet is located. The adjustment is a bolt on the rear of the injection pump that acts as a throttle stop. It is a 10mm bolt and has a lock nut on the bottom of it. Hard to see without a mirror. Loosen the lock nut, then back out the bolt about 1/8 turn (doesn't take much), relock the lock nut and you should be good to go. Over time, the head of this bolt gets worn by the throttle linkage due to vibration resulting in lower RPM's.
John (DH)
Old Aug 24, 2005 | 04:50 PM
Sawyer1's Avatar
Thanks John I will give that a try and see if it helps.
Old Aug 26, 2005 | 11:42 PM
Sawyer1's Avatar
John (DH)
I gave that a try and no difference in starting.
flyingd
17
Jul 11, 2017 11:13 AM
RED99CTD
Apr 20, 2011 08:08 AM
5.9Excursion
19
Oct 10, 2007 06:53 PM
abc4yew
Mar 15, 2007 11:55 PM
JD730
Aug 2, 2005 11:33 AM
