Rock 1 vs Truck 0
Old Aug 25, 2005 | 08:37 PM
2k1yzfr1's Avatar
Rock 1 vs Truck 0
Well today I decided to go offroading alittle bit and when we were done I looked under the front of my truck and the shock thing that runs parallel with the axle was in 2 pieces. Its the only think in front of the axle that looks like a shock. Is this the steering stabilizer? Does anyone know how much one of these are? It broke right where the bar meets the little cup like design on one side. Are you able to weld those 2 pieces back together?
Old Aug 25, 2005 | 09:15 PM
robert chilton's Avatar
yes that is the steering stabilizer that ya broke. I have no idea of the price of one but it shouldnt be to much. I dont follow your description for the break other than the mounting eyelet but I wouldnt try to weld it. preasurized gas or oil and heat from welding could be bad news. You may mess up the seal also.
Old Aug 25, 2005 | 10:35 PM
2k1yzfr1's Avatar
No its on the opposite side from the "shock" part. It is the long lod that goes metal to metal onto the cup thing. The reason I asked if I could weld it is that it looks like it was welded to begin with and I just broke the weld.
Old Aug 26, 2005 | 05:11 AM
you could probably get away with welding then. Go slow so that the heat doesnt build up. you may want to make sure that the rod isnt bent. I think that the shaft is hardened which will make the stabilizer weaker after the repair. Still best to replace it.
Old Aug 26, 2005 | 07:31 AM
smokindog's Avatar
They're really cheap. It is just like a shock. I think my buddy just replaced his with a Skyjacker variety for about $40. You'll have more time rolling out the welder, getting, set up, and waiting for the heat to dissipate than you would just to replace it.
Old Aug 26, 2005 | 08:08 AM
2k1yzfr1's Avatar
Alright I guess I will just try to pick one up today.
Old Aug 26, 2005 | 10:33 PM
blackdiesel's Avatar
Registered
yeah i would just get a new one instead of tryin to fix something of that importance. . .
Old Aug 27, 2005 | 12:05 AM
88bird's Avatar
i think they are around 32 for a stock replacement at autozone.....
Old Aug 27, 2005 | 12:11 AM
BoostdCTD's Avatar
I just paid $38 for the one from Napa.
Old Aug 27, 2005 | 12:45 AM
2k1yzfr1's Avatar
$26 for me!!!!
Zach
21
Sep 7, 2016 09:02 AM
jmccart
13
May 29, 2007 10:10 AM
Diesel Junkie
13
Apr 12, 2007 03:18 PM
Bobcat698
30
Oct 28, 2005 09:45 AM
SjLingenfelter
Mar 19, 2003 01:53 PM
