hard start hot and cold
hi, i just purshased a 1997 3500 ram and it have a starting problem everytime I want to start it, hot or cold engine, i need to apply a little pressure on the fuel pedal. If i don't do that it will not fire or if lucky maybe after 50sec and stall. My dad have a 1990 and even at -20°c it start without giving it fuel pedal. I have a base on how a diesel engine is working but it's the first time i own one. Idle rpm is like 700 rpm and the truck seem to have a lack of power between 1100 1300 rpm. This truck don't have power like other cummins i've tried.
thanks for your help and it's a nice forum, i'm learning since the first day i have my truck.
97 - Welcome! You'll find lots of info here.
Unfortunetly - you really should have noted all these traits before you put any money down to buy your truck. It's always best, if there is any doubt, to take it to a reputable mechianc and have it looked over prior to purchase, so you can approach the seller (dealer or owner) and work with the price a bit more. In addition, truck & cars should be test drive thoroughly (45+ minuites) in a variety of conditions to get a pretty good fell overall how they will perform. I also always perform a cold and hot start, just to check it out. When I bought my truck 8 years ago, I took along a friend who drives a cement truck daily for his evaluation as well.
As to the starting - 5 - 10 seconds maximum. Mine takes about 1/4 inch of pedal travel and it will start in 1/2 second or less. However my former truck - a 95 AT 4wd, started in 1/2 second with no pedal regardless of conditions. Some take pedal to start quickly, others do not.
I would reccommed changing the fuel filter, and be sure that the fuel lines (supply & return) are tight and not allowing air to leak in. There's an issue with these trucks with these lines needing replaced due to corrosion.
Lack of power - something a test drive should have pointed out. Probably due to injectors needing cleaned, or maybe a bad injector - which may contribute to hard starting.
Good luck - don't be afriad to take it back to the seller if it doesn't meet your requirements.
hi 96, i done all you said before buying the truck, checked the truck with my dad ( who owned a lot of these ) and it's why i got a good deal. i just want to know how to solve this problem i'm not afraid to put money in it, just need some explication, how-to or tips because i'm new with cummins.
dkenny
Jul 14, 2013 05:19 PM
Tazman
Jul 16, 2010 11:16 AM
duallydave
Aug 7, 2005 09:38 PM
