green oil
Old Feb 18, 2004 | 09:03 AM
Txwelder's Avatar
green oil
I am new to the Cummins world and havnt had a chance to even change the oil in my new to me truck. I checked the oil the other day and used a white paper napkin to clean the dip stick. The oil seemed to have a greenish tint to it when it got onto the napkin. The oil was changed at the dealer when I bought it about 1500 miles ago. Im used to my gasser having just a regular oil color and getting darker with more miles. Is this a problem or normal for a diesel? Thanks in advance.
Old Feb 18, 2004 | 09:21 AM
Lil Mule's Avatar
Muted User
May just have to do with the brand of oil they used.
ATF is normally red - Dye
Daewoo equipment uses same ATF and it comes from the factory green - Dye
Euclid equipment now come from the factory with bright red hydraulic fluid, green gear oil 80/90, and yellow engine oil to aid in leak detection
Someone here may have more info, but I'm guessing it's the normal color of the oil.
Old Feb 18, 2004 | 09:45 AM
Commatoze's Avatar
Sometimes when you 've got relatively fresh oil in the crankcase, a little suspended soot gives the amber oil a greenish/grayish tint to it. If I were you, first thing I'd do is to change the oil and filter; you don't know what's in there. Replace it with API CH or CI rated oil (although CF/CG is acceptable for your engine), install an approved filter like a Fleetguard and change your fuel filter.
Old Feb 18, 2004 | 10:46 AM
thumper 549's Avatar
if you have real good collor vision the better oils have a tint of green............just a tint but most do not notice so no worries
Old Feb 18, 2004 | 11:45 PM
dsljunkie's Avatar
It could be the Delo UV product. It is used to find oil leaks. You run the UV oil for a while and use a black light to find the location of your leak. Pretty COOL stuff.
Scott
Old Feb 19, 2004 | 10:39 PM
tmoore's Avatar
Today I checked the oil in my 91 and the oil had a greenish tint to it as well. It was just changed about 3 weeks ago 4-500 miles. I had never saw it look like that before, I didn't know if it was because of a differnet brand or what. I used rotella same as I do in my other one, never noticed it having greenish color to the oil before.
Old Feb 19, 2004 | 11:00 PM
Tfeore's Avatar
I think that it's the UV dye, my first oil change came out almost army green. Put the new oil (premium blue) in and it was normal oil color.
Had a little leak at the valve cover and sure enough the oil is green again. Service adviser told me they put a dye in it and "when I bring it in for it's next oil change" they will look it over with a black light.
As if I'm gonna let them do the oil change
Old Feb 22, 2004 | 02:39 PM
Txwelder's Avatar
I was almost scared that I had some kind of problem with diesel getting into the oil but that hasnt been an option on any response so I can cancel that idea. Thanks to all!
Old Feb 29, 2004 | 07:16 AM
ReedRosa's Avatar
I have used Delo 400 since day 1 in my truck and yesterday checked the oil and found this green tinted oil. I have never noticied this before and I have had this truck almost 5 years. I wonder if it is something Delo has chaged in thier oil? It is clear and clean, but definantly has a green tint. Scared the heck out of me too. Thought it might be a coolant leak into the oil or somthing.
APD
Apr 17, 2015 06:22 PM
apwcu
Sep 8, 2011 08:59 AM
ktowndog
Apr 16, 2010 01:00 PM
blizz
Mar 12, 2008 07:16 PM
CUMMINSBILL
May 16, 2003 06:05 AM
