governor springs
Old Jan 24, 2007 | 08:36 PM
Harold Swanson's Avatar
governor springs
Was going to change gov springs,took off intake,fuel shut off sel,removed plug and could not even see springs. Howare you able to do it?
Old Jan 24, 2007 | 09:05 PM
Cummins Freak's Avatar
i think you need to bar the engine over to get the springs to show up
Old Jan 24, 2007 | 09:09 PM
Fueling around's Avatar
You have to "bar the engine". This will turn the pump and bring the top of the spring stack into the plug opening.
Breaker bar and socket on the alternator nut will work. Better if you have a barring tool which plugs into a hole in the block and connects to the ring gear. Barring tool you can go CW & CCW. Alternator nut is a one way only.
Leadfoot
Nov 28, 2005 04:26 PM
crossy
May 22, 2005 10:33 AM
Getrealgetlifte
Mar 5, 2005 05:38 PM
mr T
17
Jan 6, 2005 11:29 PM
Monty
Feb 16, 2003 03:52 PM
