Governor Lever adjustment
Old Jan 31, 2005 | 12:12 AM
Randy Hardesty's Avatar
Question Governor Lever adjustment
I was trying to adjust the governor lever on my #10 plate and dropped the screw down in the pump.Am I in a world of hurt or not? I put it all back together and the truck runs fine. Will this hurt anything to leave the screw out or should I get a new screw ?
Thanks,Randy
Old Jan 31, 2005 | 01:19 AM
P.O.R.'s Avatar
i would be gettin that screw out of there, use a magnet and go fishing, leaving that screw in there would make me sick
Old Jan 31, 2005 | 10:08 AM
jimk's Avatar
Re: Governor Lever adjustment
Thanks,Randy
Randy I have done the same thing. Take about ticking off. Any way fish the screw out with a magnet. I did not wont to risk trashing the pump. good luck Jim
Old Jan 31, 2005 | 11:06 AM
gunracer1's Avatar
man get that screw out, i would spend all day if need be to get it out. i have dropped springs and the nut for the gsk in the pump and all were fished out pretty easy.
Old Jan 31, 2005 | 11:31 AM
vssman's Avatar
98Rammer did the same thing you did and wound up having to put in a new pump. The screw bent some rods inside the pump. Definately get that screw out before you run it again...
Old Jan 31, 2005 | 02:09 PM
DZLPWR's Avatar
Ive dropped that screw more inthan my hands can count. Fished out everytime. There is a washer on it too. I would not start the truck untill the screw is out.
Old Jan 31, 2005 | 04:37 PM
What is the best location to fish through? Should I go in thru the hole on the back of the pump were the screw was located or is there an easier way?
Thanks ,Randy
Old Jan 31, 2005 | 05:48 PM
gunracer1's Avatar
the back would be fine, just get it out. get a strong magnet about 3/8 in diameter or less.
Morej
Nov 8, 2008 04:48 PM
pro puller
Dec 24, 2007 09:59 AM
dontoy
Sep 10, 2007 08:06 PM
dontoy
Sep 10, 2007 02:16 PM
Got Smoke?
Mar 20, 2003 07:48 PM
