gov spring kit
Old Jan 7, 2003 | 12:23 AM
  #31
VinDiesel's Avatar
Re:gov spring kit
Got Smoke?,<br><br>Did you try backing off your idle stop bolt? It is quite common to have to reset the idle after the kit. I'd certainly try that first. Now if you screw the stop bolt down all the way, and it's still idling too high, you'll have to back off 1 or 2 clicks. Don't forget the locknut on the bottom of the casting. Mine was very tight or a little stuck, I used a 6 point 10mm socket &amp; 3/8&quot; rachet to break it loose so I could adjust the bolt.<br><br>Also consider that part of the benefit of the kit is increased throttle response, so the pedal will be more touchy. The profile of your fuel plate could come into play- the tab might drop off a high point at that certain rpm, giving a rather sudden increase in fuel. &quot;Improved&quot; (application specific) fuel curves are why aftermarket plates are sold.
Old Jan 7, 2003 | 12:29 AM
  #32
Got Smoke?'s Avatar
Re:gov spring kit
[quote author=VinDiesel link=board=16;threadid=8995;start=30#89269 date=1041920584]<br>Got Smoke?,<br><br>Did you try backing off your idle stop bolt? It is quite common to have to reset the idle after the kit. I'd certainly try that first. Now if you screw the stop bolt down all the way, and it's still idling too high, you'll have to back off 1 or 2 clicks. Don't forget the locknut on the bottom of the casting. Mine was very tight or a little stuck, I used a 6 point 10mm socket &amp; 3/8&quot; rachet to break it loose so I could adjust the bolt.<br><br>Also consider that part of the benefit of the kit is increased throttle response, so the pedal will be more touchy. The profile of your fuel plate could come into play- the tab might drop off a high point at that certain rpm, giving a rather sudden increase in fuel. &quot;Improved&quot; (application specific) fuel curves are why aftermarket plates are sold.<br>[/quote]<br><br>Personally I think I'd rather back the springs off one click before trying to reach down even further for the idle bolt and nut! <br><br>I do however believe that I have them tight because yes I do have noticeable increased throttle response, but I should still be able to hold a steady RPM in between 1,000 and 1,500 I believe? ??? [undecided]<br><br>I plan on calling PDR tomorrow and see what Al or Piers have to say about it. I have a feeling Al's gonna tell me to back the springs off 1 click anyways.
Old Jan 9, 2003 | 07:54 AM
  #33
turbospl311's Avatar
Re:gov spring kit
I have instructions from TST on going through the top. Anyone have a set of instructions on going through the side they can scan in and send me? I already put in a cam plate last year and would like to compare the side route based on that.<br><br>Thanks, Don<br>turbospl311@yahoo.com
Old Jan 9, 2003 | 08:29 AM
  #34
nevrenufhp's Avatar
Re:gov spring kit
The Piers instructions go thru the side, My scanner can't make it legible...sorry. How about a fax#?
Old Jan 10, 2003 | 07:50 AM
  #35
Re:gov spring kit
FAX number is 208-396-6357. Attention: Don Miller
Old Jan 12, 2003 | 06:38 AM
  #36
98rammer's Avatar
Re:gov spring kit
VinDiesel, he has 181 delivery valves, they should provide enough fuel to not stumble or stumble very little. of course every pump's tolerances are different...<br><br>i hit 3500rpms twice in neutral...wont do that again. i had to back down on the power due to the tranny (high rpms+low pedal -low line pressure- = BAD), but at least i can wind her out in 3rd very good. defore i moved my plate back: WOW.<br><br>side of the pump- only way to really do it. a tip i learned was to simple count the number of turns the retainer nut turns until it's flush with the top of the springs.<br><br>my idle went up...a little too high, but it starts better in cold weather now!<br><br>Tom
Old Jan 12, 2003 | 12:10 PM
  #37
VinDiesel's Avatar
Re:gov spring kit
[quote author=98rammer link=board=16;threadid=8995;start=30#91161 date=1042375135]<br>VinDiesel, he has 181 delivery valves, they should provide enough fuel to not stumble or stumble very little. of course every pump's tolerances are different...<br>[/quote]<br><br>I'm hoping the 370s will work pretty well with the 180hp pump.<br>After waiting for a while for Bosch to make another run of 300s, I've gone ahead and decided to go for broke (hopefully not my tranny ) and bought a set of 370s! ;D
Old Jan 12, 2003 | 01:16 PM
  #38
nevrenufhp's Avatar
Re:gov spring kit
I must say the 370 are just KILLER!!!! &amp; didn't have the mosquito abatement fog like I thought. It burns relatively low smoke at full WOT.
Old Jan 12, 2003 | 05:23 PM
  #39
98rammer's Avatar
Re:gov spring kit
well Vin, at least you have the transgo; i just wonder how that torque converter will hold up. nevrenufhp- well, we'll see ;D
Old Jan 12, 2003 | 06:19 PM
  #40
nevrenufhp's Avatar
Re:gov spring kit
The way I'm starting to drive it it'll last about a month or 2. : oh well.
fishin fever
Mar 13, 2006 06:46 PM
Txwelder
Sep 11, 2005 06:00 PM
rebal
Feb 22, 2005 01:12 AM
Jim Shulmister
Mar 8, 2003 09:07 AM
NeedMoPower
Feb 17, 2003 01:00 AM
