Gov Spring Kit
Old Sep 10, 2005 | 09:22 AM
Txwelder's Avatar
Gov Spring Kit
Is there a way to modify the GSK by tightening the springs more or loosening them from original specs to make them operate differently?
Old Sep 10, 2005 | 11:53 AM
mr T's Avatar
u mean the stock springs? i dont think so really...ive hear that u can try a click or two to tighten them but no real change
Old Sep 10, 2005 | 01:26 PM
Txwelder's Avatar
No not the stock springs, the 3kGSK. If they are tightened more than what my stock springs were will it make a difference in the RPM limit they will govern?
Old Sep 10, 2005 | 03:01 PM
Jambbii's Avatar
Yes, a couple clicks (I think 2 tighter) will bring the limit up a 100 or 200 rpm.
Old Sep 10, 2005 | 09:48 PM
Jeremy Cusick's Avatar
Gunracer has a theory that if you were to shim the underside of the center spring on the stock gov. springs, it could yield the same results as the 3K GSK. He thinks a 5/16" flatwasher will fit.
I want to try it, but haven't the time or notion.
Old Sep 11, 2005 | 12:00 PM
cumminsdriver635's Avatar
I had mine a couple clicks tight when i installed them would pull to 3200 or so before it quit fueling. It was a little harder starting though, so i loosened them up couple clicks, and now its starts fine again. I have been thinking about tightening them back up though, becuase i liked the way it ran better with them tighter.
Eric
Old Sep 11, 2005 | 06:00 PM
squirlchasr919's Avatar
I think if you make them too much tighter though you will increase the idle of the motor. I had mine way too loose on the first try and the truck would barely run, I'm talking 100-200rpm idle. Next we made them too tight and it idled at about 1000rpm. You could just adjust the idle screw on the pump to alter the idle, but I got mine as close as possible before I messed with anything else.
fishin fever
Mar 13, 2006 06:46 PM
rebal
Feb 22, 2005 01:12 AM
Jim Shulmister
Mar 8, 2003 09:07 AM
NeedMoPower
Feb 17, 2003 01:00 AM
boehunter49
39
Jan 12, 2003 06:19 PM
