Gauge questions
Old Feb 2, 2011 | 08:46 PM
skog8301's Avatar
Gauge questions
Hey everyone I recently bought a 97 3500 5 speed I was wondering about putting gauges in it other than egt and boost I want to know if people have put gauges in their diffs or their manual trans and oil temp and where to put the temp sensor I know it would be over kill but I like knowing everything my truck is doing. Any info would be much appreciated.
Old Feb 2, 2011 | 10:07 PM
gorms's Avatar
Fuel pressure is great to know, might show a problem before it shows up. Trans temp is something I'd like to do my self, not sure of the best place to put it on a 5 speed. I have some extra PTO covers, I may try either welding a bung into it or finding a bulkhead fitting. For differentials, people usually put it in the cover. Aftermarket covers sometimes have a threaded hole in them already, otherwise I think it would be the same deal.
Old Feb 3, 2011 | 11:04 AM
infidel's Avatar
I once had engine oil and manual tranny temp gauges but they were boring, hardly moved, so I removed them.
Fuel pressure and intake air temp are much more interesting and helpful.
Old Feb 3, 2011 | 06:43 PM
skog8301's Avatar
Where did you get the air intake temp gauge
Old Feb 4, 2011 | 12:00 AM
skog8301's Avatar
Has anyone ran a fuel restriction gauge along with fuel psi
Old Feb 4, 2011 | 11:22 AM
chariotdriver's Avatar
Fuel pressure drop across the filter would be nice; also the best way to know when it is getting time to change it. Does anybody know where to get one? What does intake air temp tell-----intercooler efficiency?
Old Feb 4, 2011 | 12:27 PM
infidel's Avatar
I used a Cyberdyne tranny temp gauge that reads 0-300°F.
Put the sender in the airhorn about 6" upstream of the grid heaters.
It's on a toggle switch that I can switch back and forth from intake to tranny temps. It's mostly set in the tranny position.
I used it experimenting with different intakes but it's sort of interesting and easy to do.
Cyberdyne gauges> http://www.jegs.com/v/Cyberdyne/280?...FRhzgwod1j90Fw
Here> http://www.westmarine.com/webapp/wcs...4&ci_sku=19628
Fleetguard also sells one.
My regular FP gauge works just fine for filter condition. Cruising at 2000 rpm on a flat road it always reads 32 psi until the filter starts plugging. I change the filter when it drops 3-5 psi.
Old Feb 4, 2011 | 02:20 PM
skog8301's Avatar
Is there a number to look for in air intake as far as what to avoid
mtl0727
Oct 12, 2005 01:02 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
