gas to diesel fuel tank issues
Old Jun 5, 2012 | 07:04 PM
96dodge2500's Avatar
im swapping a 12v engine in to my truck the truck is a v10 what do i need to do to the fuel tank?Fuel pump? and i noticed the v10 didnt have return lines how do i add this for the diesel?
Old Jun 5, 2012 | 10:30 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Try and get a fuel module from a diesel truck fuel tank...I'm not sure..but it should screw to the top of the gas tank you have..
Old Jun 6, 2012 | 07:45 AM
patdaly's Avatar
Never seen a V10 module, but if it has the rubber grommet to hold the fuel lines in, a Vulcan draw straw would work.
Old Jun 6, 2012 | 08:29 AM
i read somewhere that you can just remove the pump it self and place a tube in place so that you can still have your sending unit not sure
Old Jun 6, 2012 | 04:58 PM
patdaly's Avatar
But if you don't have a return line on the V10 you will have to add one. If the lines go to a bung that pushes in with a rubber grommet around it, you can simply pull that out and replace it with a draw straw, which has both supply and return last time I bought one it was around 50 bucks, easier than cobbling something together. Diesel modules used to be cheap on fleabay, but no more. Vulcan performance also sells the Liberty module upgraded, but it is close to 300 bucks.
Hodge
Aug 18, 2009 08:43 PM
dodgerdog
Feb 23, 2009 10:54 AM
EverydayDiesel
Jan 15, 2008 01:17 PM
rollo_t
Feb 5, 2007 09:21 AM
jerdman
Oct 17, 2005 09:50 PM
