Fumes in cab
Old Dec 17, 2013 | 06:08 PM
Sleigher's Avatar
Fumes in cab
My truck is starting to make me sick.
If I am bringing outside air in (not recirculating) I am getting diesel fumes.
I suspect that I have some leaking flanges.
Can anybody point me to the right flange gaskets? (94 12 valve).
I've looked at Rock Auto and I guess they might be standard exhaust donuts but I'd rather have the parts on hand when I take it apart.
Any help is appreciated, as always.
Thanks in advance.
Peter
Old Dec 19, 2013 | 02:26 PM
infidel's Avatar
Check if the gasket that seals the back of the hood is off.
It's common for them to partially fall off. Fumes will most definitely come in the cab then especially if the truck isn't moving.
I use 3m molding adhesive to glue them back on
Old Dec 20, 2013 | 06:42 PM
Sleigher's Avatar
Thanks Bill,
Are you talking about the gasket that runs the width of the engine compartment?
This does come loose on one end but it has done that since the truck was new.
I push it back on and that's it.
If I am recirculating the air I don't have a problem but in the morning when I am using the defroster I come to a stop at the bottom of the first hill and I get a good dousing.
So what you are saying about when I am sitting still makes sense but the gasket is about the same as always.
I didn't even think about the breather tube. Could it just be the 276,000 miles is making more fumes from the breather tube?
Thanks again.
P
Old Dec 20, 2013 | 09:01 PM
gorms's Avatar
I've got the same problem, pretty sure it's from the breather tube (or lack of). It's not always there but sometimes it gets stinky, seems to be worse when I block the radiator off.
Somewhere I saw a charcoal filter element kit that goes in the cowl somehow, maybe genos? that should reduce the smell if I ever get around to trying it. I don't sit in much traffic usually.
Old Dec 23, 2013 | 01:30 PM
infidel's Avatar
That's the one.
There are also some styrofoam pieces that seal the back of the underhood in the space between the fenders and firewall that come loose and end up in the wrong place.
Maybe the seal at the rear of your engine compartment is smashed down too much with age and isn't sealing good.
It's only a 3 inch jump from the underhood to the vent inlet.
Scotty
53
Mar 3, 2005 07:24 PM
riderdog
Dec 12, 2004 04:39 PM
tractor-man
Feb 20, 2004 10:25 AM
Hairy1
18
Nov 11, 2003 10:40 AM
KRN
14
Jun 1, 2003 06:54 AM
