Fuel Shutoff Solenoid Boot - Need Source
My truck wouldn’t start yesterday So I started troubleshooting the fuel system. I determined that the solenoid wasn't pulling on start but would stay up if I pulled it manually. I found that the relay contacts were burned and after filing them the truck starts fine.
I removed the solenoid to check it over and see that the rubber boot is completely dry rotted. Anyone know a source for a replacement boot?
Bob
Bob
www.fostertruck.com for the boot and for starter contacts
You mentioned the relay contacts were burned. Are you referring to the fuel solenoid relay mounted on the engine cowl or the starter contacts? If the relay, I guess you pulled it apart to fix it. The foster truck website also has the relay but it can be found cheaper too? I'd replace the relay and keep the old as spare but to each his own.
I used a piece of bicycle inner tube on a tractor solenoid that has an identical boot. So far, it has worked fine.
I was thinking about a bicycle tube last night. It would be about 1/10 the price of a new boot.
The relay was burned. I am talking about the relay on the cowl. I used three screwdrivers to pop it apart and I removed the contacts and filed them. I am ordering a new one from Rock Auto and keeping this one for a spare. I know it will fail again someday.
95black2615
Oct 8, 2008 03:34 PM
