fuel shut off solenoid
can someone point me in the direction as to where the solenoid is ?. truck will run but die within a couple of seconds. or will not start at all. cracked the fuel lines and getting some fuel but not alot. under 100,00 miles so i dont think its the ip.
Location: Climax, MI (between battlecreek and kalamazoo)
Are you asking on a 12v or on a common rail? your sig shows a common rail and that doesn't have a fuel shut off solenoid per say.
the shut off solenoid is near the back of the pump, it has a boot covering a shaft that pulls the fuel lever up and down, when you pop the hood stand on the driverside of the truck, staring at the side of the engine where the injector pump is you will see near the back of the pump on the side of the pump a solenoid with a wires coming out of it (only electrical thing on the pump) the wires probably have a plastic cover on them. heres a pic, the solenoid has the blue plastic wire shielding coming off it. (lever in up position is run, down is off)
https://www.dieseltruckresource.com/...e_pics_046.jpg
jason
jason
The solenoid rarely goes bad, you will be wasting money to replace it, lots of it.
if you take it off and replace it, send it to me, Ill pay shipping, I want to do some measuring off of it, as I do not have 1 on my truck to measure!, my shutoff solinoid has ben MIA!!, replaced with a spring and kickdown cable....
skywalker175
05-13-2003 02:37 PM
