fuel shut off help
Old Sep 22, 2006 | 10:52 AM
wildcard's Avatar
it cant be that because it wouldnt start before I changed the filter and when I changed it nothing changed.
Old Sep 22, 2006 | 11:05 PM
wildcard's Avatar
I pulled up the shutoff plunger manually and cracked the # 1 injector loose and I still had no fuel comming out, I have fuel the the injector pump and nothing comming out. please help?
Old Sep 23, 2006 | 11:19 AM
Baja's Avatar
OK, you crank the engine and fuel will come out at the banjo bolt, the one that attaches to the IP, correct?
You now crank the engine with a cracked injector line and you get no fuel pulsing out? Crank it longer, loosen it more, not too much, look for fuel.
If that is all correct, it seems that you have isolated the IP, but for that to just up and die is really strange, the P7100 is really tough. It could happen I guess, but at this point, I would have to take it to someone who is more knowledgeable and talk to them. Sorry I can't be of any more help, good luck.
Old Sep 23, 2006 | 04:37 PM
clutch1's Avatar
Baja has it correct if you do what he says and still nothing, problem is at the inj. pump.
Old Sep 23, 2006 | 07:08 PM
wildcard's Avatar
all that is correct.
Old Sep 24, 2006 | 06:56 PM
wildcard's Avatar
Ok I got he shut off solinoid working the blue wire was all green at the battery so with a new end It was working again but it still doesnt start.
Old Sep 25, 2006 | 10:30 AM
infidel's Avatar
You probably still have air in the system, most likely in the injection pump. I've had times when it's taken minutes of cranking to expel the air. Open at least three lines at the injector and crank. Make sure your battery charge stays up, the engine can seem like it's spinning fast enough to start but never will.
Smokkin
Apr 4, 2012 02:43 PM
dkimmel
Jan 3, 2011 10:54 PM
deezul
May 4, 2009 05:33 PM
randyswelding
Feb 9, 2009 10:40 PM
Dean Snow
Sep 26, 2007 03:40 PM
