fuel pump
Old Apr 20, 2010 | 03:56 PM
crappie59t's Avatar
fuel pump
i have completly swapped my 1500 cab over on to my 2500 frame we switched the dashes and everything works, it turns over but it will not start because it aint gettin any fuel, does any one know if their is a reset on the fuel pump or any thing else that could be wrong
Old Apr 20, 2010 | 05:48 PM
patdaly's Avatar
What year truck are we talking about here?
Old Apr 20, 2010 | 06:09 PM
crappie59t's Avatar
Old Apr 20, 2010 | 07:36 PM
Tate's Avatar
Theres no reset on the pumps, they are all mechanical. You might not be getting power to the shutoff solenoid. Pull the solenoid off and see if it fires up. Push the lever down to kill the engine when it fires up.
Old Apr 21, 2010 | 07:21 AM
patdaly's Avatar
Yep, wire the solenoid up and see if she starts. If she does, then wiring to it is the issue, if not push the primer on the LP until you hear it sing, or make a hissing sound up by the Injection pump and then try starting.
Old Apr 21, 2010 | 09:15 AM
crappie59t's Avatar
ok thanks
Old Apr 21, 2010 | 09:27 PM
kddieselperform's Avatar
if you have a hard time getting a prime by pumping the primer than just spay some starting fluid in her to get it started and that should quicken the process. if you cant get it going after the 3rd or 4th try with starting fluid than you arent getting fuel. that is if your shut off solenoid is off and set right.
Old Apr 22, 2010 | 08:36 AM
patdaly's Avatar
DONT spray Ether.......... I have run them with brake cleaner, WD40, etc.
Hitting it with Ether should be considered abuse......
ScreaminEagle
Oct 31, 2007 03:31 PM
Stevie G
13
Aug 4, 2006 10:27 PM
Gene
Sep 10, 2005 09:32 PM
Commatoze
19
Aug 8, 2004 09:57 PM
TPilaske
16
Nov 22, 2002 08:15 PM
