Fuel Line Replacement
Old Jun 25, 2012 | 07:47 PM
MrKen's Avatar
Time to do this. I have done the engine side, now for the tank side. I have the bed tilted 4", so fairly good access. Supply side is off. I cant remove the return line. The quick connect does not seem to come off. The line slides in/out 1/4", looks like a plastic locking ring turns around in the connector. Any tips or pics that can tell or show me how this is done? The connector on the tank is plastic, and I prefer not to break that. Thanks for any help and advice.
Ken
Old Jun 25, 2012 | 08:12 PM
gorms's Avatar
I had a tough time with my return as well, just did them last week. I ended up just snipping the thin spot of the black plastic line with dykes and peeled the retaining clip out in peices. I just used SAE rubber hose to replace it, so I shaved the ridge on the hose barb (on sending unit) so I could get 2 good clamps on there. Good luck.
Old Jun 25, 2012 | 09:51 PM
BigIron70's Avatar
Cummins Guru
Sometimes I use a pair of small needle nose vise grips and adjust so they just pinch the plastic lock enough to remove line. I have large hands and this has worked for me in the past.
Old Jun 26, 2012 | 08:30 AM
patdaly's Avatar
They also get filled with gunk making it harder to compress the clips.
I just cut mine off, replaced with rubber.
Old Jun 26, 2012 | 10:00 AM
infidel's Avatar
One more for hose clamps instead.
Old Jun 26, 2012 | 11:13 PM
MrKen's Avatar
Thank you for the replies. I used a dremel and cut the connector apart, great idea. I double clamped both sides, both lines. Thanks again!
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
Rockyhud
Oct 8, 2004 09:29 AM
doodah
Jan 22, 2003 07:11 PM
blackboat
Oct 27, 2002 05:52 PM
