fuel leak. where to get new metal lines?
Old Nov 26, 2010 | 08:09 AM
97dodgeram2500's Avatar
so i got a leak comin from where the metal line turns into the metal mesh line. where can i get replacement lines? if anyone knows
Old Nov 26, 2010 | 08:38 AM
AlpineRAM's Avatar
I usually replace them with 3/8" ID rubber hose (Gates AutoMaster MultiFuel because it is Bio-Proof) from the tank forward.
HTH
AlpineRAM
Old Nov 26, 2010 | 10:26 AM
why would you replace metal lines with rubber line? just wondering how that works.... but i think its leaking from inside that steel braided line and if i understand correctly its a rubber line inside that
Old Nov 26, 2010 | 11:24 AM
patdaly's Avatar
Factory lines are horrendously expensive. When I priced them 4 years ago the good guy price was almost 200 bucks each. Then you had to get the engine side hoses on top of that.
I just bent some 3/8" and 5/16" lines to roughly match, and used good diesel fuel line to do the ends.
30 bucks versus over 400......that's why.
Old Nov 26, 2010 | 05:45 PM
infidel's Avatar
I've abandoned the junk stock lines and replaced with hose from engine to tank on a couple dozen trucks, no problems.
If you buy high quality marine diesel hose it will easily last the life of the truck and will cost a quarter of what the dealer wants for their junk.
Hose 5/16" return and 3/8" feed.
mattmanj2001
Aug 19, 2010 08:18 PM
schoust
Sep 1, 2009 06:54 PM
kawi600
May 4, 2006 09:43 AM
tyssniffen
Mar 21, 2006 05:24 AM
greenworks
Feb 28, 2005 10:15 AM
