fuel fitler 12v question
Old Oct 19, 2009 | 09:25 PM
winkdemon's Avatar
just wondering if any of you guys no the filter part number for a fuel filter that does away with the stock filter that has the bung in it for the the water sensor????
but goes on the stock bulk head ...
thanks
Old Oct 20, 2009 | 12:09 AM
Dr. Evil's Avatar
Is this the spin on filter or the drop in one? What year are we talking about?
Old Oct 20, 2009 | 12:25 AM
ttcfan4476's Avatar
me too
Old Oct 20, 2009 | 07:55 PM
ttcfan4476's Avatar
the spin on that would delete the WIF sensor
Old Oct 20, 2009 | 11:17 PM
winkdemon's Avatar
SORRY GUYS , SPIN ON , IT FOR A 95 P-PUMP TRUCK , I HAVE TWO FILTERS ON THE TRUCK , THE FIRST ONE HAS WATER FILTER IN IT WITH MY WIRING HOCKED UP SO I DON'T NEED TWO BUT I WANT TWO FILTERS
Old Oct 21, 2009 | 03:54 PM
winkdemon's Avatar
anyone ?
Old Oct 21, 2009 | 07:31 PM
infidel's Avatar
If you can't find one I've heard of folks using a commonly available auto parts oil drain plug to block off the sensor hole.
Just ran into it on another website, Napa 3395 has the solid bottom.
Old Oct 21, 2009 | 10:09 PM
winkdemon's Avatar
sweet thanks . the big thing is the price of it , if i can't get one i will just change the bulk head ,
Old Oct 22, 2009 | 03:09 AM
Fueling around's Avatar
Do you have a Case IH dealer close? The new Magnum use 2 nearly identical filters side by side except the primary filter has the water separator valve & sensor.
Sorry, shop is 15 miles away to go check the numbers on the filters in the bin.
Old Oct 22, 2009 | 10:23 AM
infidel's Avatar
Is $14 a good price?
Old Oct 22, 2009 | 10:55 AM
winkdemon's Avatar
yep 6.99 is a good price that my cost on it ... thanks for the help guys
Old Oct 23, 2009 | 04:46 AM
wcbcruzer's Avatar
Since we're on the topic of fuel filters... Is there any 2-micron fuel filter that'll fit the stock location on a 1996 12v? If not, what's the best filter I can get?
Old Oct 23, 2009 | 01:12 PM
Dartmouth 12V's Avatar
Yep, Napa 3395 works. I have one on my truck right now since it was the quickest thing that I could get to fix a leaking WIF sensor. I think it was something like $15 from napa which isn't too bad.
Old Oct 23, 2009 | 07:29 PM
winkdemon's Avatar
ya i went and got a flat of them ....
Old Oct 24, 2009 | 08:31 PM
A bit off topic, but goes with the discussion.
Bill (Infidel) should have seen the neat accesory John Deere includes with every fuel filter cartridge. A funnel that screws onto the filter and blocks the inner (filtered fuel) side, but allows pre-filling the filter. Makes a fast engine re-start after changing filters in the field
Forgot to look at the Case-IH P/N on the filter, too
