Fuel filter
Fuel filter
Since I have a supply of K-1 kerosene and no diesel fuel as yet,can I:
Use the kerosene to fill the canister after changing the fuel filter?
Would this create any problems?Thanks.
Shelley
Shelley
Is it filtered? If it is you probably could, might run a little rough till its out of the system. Dunno I've read you can run these on kerosene but I've never seen one run it in person.
Whats wrong with just hitting the primer button 50-100 times and ruling out any problems?
Use a broom stick to reach the plunger.
I never use the primer or prefill the filter. Open the bleed screw on top of the filter housing and pressurize the fuel tank with an air blow gun wrapped in a rag. Takes about 15 seconds to fill the filter and purge all air.
Of course you have to have an air compressor though.
Originally posted by northslope
I heard of a mechanic up here that primes ALL diesel filters with ATF, good or bad
ATF is designed not to burn and will leave damaging ash deposits in your engine.
Some people prime with straight diesel fuel additive with no problem, I personally don't see any advantage to it though.
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
