Front rotors..... best way to remove?
Old Jul 7, 2009 | 10:21 PM
lilsuzuki4x4's Avatar
So I have to replace front rotors on my '97 2500 4x4 I have done these before they were just a pain inna but to get off!! Any help or ideas would be appreciated!!! I know there is a better way than just beating the heck out of them. Thanks in advance as I know good help will arrive in a few short hours!!!
Old Jul 8, 2009 | 05:47 AM
Yellow Yota's Avatar
Use a socket and extension to act as a press while you turn the steering wheel. The socket goes on the loosened bolt head that holds the bearing to the knuckle, and the other end of the extension goes against the end of the axle.
Either use a press or a brass punch to remove the wheel studs without galling them.
Make sure to clean up the inside surface of the knucle and the outside of the bearing before you reassemble. Also, put a bit of anti-sieze on the outside of the bearing so it's easier to get apart next time.
Old Jul 8, 2009 | 06:19 AM
JP-4.5's Avatar
Yota,
I have only owned a 3rd gen and the rotors come off all by themselves. Are the older trucks rotors part of the hub assembly?
Old Jul 8, 2009 | 08:14 AM
cmac's Avatar
yes the rotors are "pressed" together with the wheel bearing by the wheel studs.
Old Jul 8, 2009 | 09:38 AM
infidel's Avatar
Read my write-up here https://www.dieseltruckresource.com/...6&postcount=10
Old Jul 8, 2009 | 12:46 PM
smokeyram's Avatar
the best way to get them off is to have the brake shop do it, the second best way is infidels method shown above.
Old Jul 8, 2009 | 05:01 PM
Originally Posted by infidel
Exactly the method I was trying to explain. I didn't think about looking for the old thread.
Old Jul 8, 2009 | 06:44 PM
Amos's Avatar
I think infidel's thread:
should be made a sticky as this issue and his corresponding solution come up quite often.
Old Jul 8, 2009 | 07:23 PM
infidel's Avatar
It is
Top thread in the 12 valve forum labeled "Common Problems and How Do I Articles"
Old Jul 8, 2009 | 09:02 PM
Thanks guys!!!! I knew there was a better way than I have done in past!!!!
Together we will keep these good ol trucks on the road!!! CHEERS!!!
Old Jul 15, 2009 | 09:34 PM
heykw's Avatar
After doing numerious brake jobs to my 98 I switch out the axels to the newer style front and rear axel. imo it is the best mod I ever did to my 98
rbertalotto
Sep 9, 2009 02:17 PM
Tuf-4x4
13
Apr 27, 2008 11:56 AM
04ctd
Aug 3, 2007 04:19 AM
njmaier
Apr 26, 2005 08:13 AM
bullfrog
Mar 11, 2005 11:53 AM
