front end work, need info
Old Nov 25, 2009 | 04:49 PM
94ram's Avatar
well, what was suppose to be an alignment done on my truck ended up being an estimate of how much its going to cost for a new trac bar, tie rod, alignment and labor. so instead of being 40 bucks, its going to cost me about $600! that doesnt seem like much but im on a very very low budget since im goin to school and living on my own.
my question is, besides the alignment, is it worth me trying to do the job myself, and if so, where can i find cheap good quality parts?
the last thing i needed was to fork over a big chunk off my wallet
thanks, sal
Old Nov 25, 2009 | 05:15 PM
b.lee's Avatar
Get the tie rod from napa
and get a 3rd gen trac bar kit to replace your 2nd gen trac bar
I replaced my stock trac bar once and only got 25,000 miles out of it
I replaced it again with a 3rd gen trac bar kit, and that was money well spent.
Don't buy a stock or a stock replacement trac bar, they are junk
Old Nov 25, 2009 | 05:18 PM
94ram's Avatar
where can i find a 3rd gen bar and are they relatively cheap?
Old Nov 25, 2009 | 07:00 PM
turfguy's Avatar
had same thing happen to me on my gas dodge 3/4 ton-forgot to frickin grease the zerks- a $725 mistake!!!!!!!! I went with MOOG from a local parts house
Old Nov 25, 2009 | 08:43 PM
infidel's Avatar
I find it hard to beat a $150 lifetime warrantied trackbar from Napa.
Even if it only lasts 25k miles it's no big deal to swap in a new one, ten minute job.
My Napa bars have been lasting about 60-80k though.
3rd gen bar and the relocation kit will run you at least $500, and they wear out too.
Old Nov 26, 2009 | 06:59 PM
94ram's Avatar
yeah i was thinking NAPA would be my best option.
so do you think that i can install the track bar and tie rod myself and then just have the shop do the alignment? my time limit would be a saturday, so is it achievable?
thanks for the input guys,
sal
Old Nov 26, 2009 | 07:23 PM
b4black's Avatar
Check out a luke links for the track bar. Rock Auto is a good place to get the tie rods cheap (do you know which part you need? There are four parts that are called tie rods ends.)
I just did both. Use the search function for luke and tie rod. You'll find plenty of great info.
Old Nov 26, 2009 | 08:18 PM
94ram's Avatar
im guessing the inner tie rod? the part that goes from the wheel to the part that connects to the pitman. the part that connects to the pitman was just replaced a couple of months ago so that doesnt need replacing, just the metal shaft that connects to the passenger side wheel.
Old Nov 26, 2009 | 09:00 PM
94ram's Avatar
i just checked out Lukes Link. im thinking am going to go with the rebuild kit for the track bar. as for the tie rod, compared to lukes link diagram, i need the right hand connecting rod, i need to completely replace due to the fact that it is considerably bent.
Old Nov 30, 2009 | 07:32 PM
Clarkkent's Avatar
I just tried to install luke's link, turns out I had a moog track bar, it' didn't fit. they do sell re-worked track bars already for the same money as the lifetime ones from the parts stores.
tie rods were made to be straightened!! just ask anyone with a jeep.
kent
Old Dec 1, 2009 | 08:30 AM
smokeyram's Avatar
take a look at the HD parts, i believe for 97-98.
id have to check the years but the parts are beefier.
Im with Infidel, get the warranty part, its an easy swap when they go.
I tried a Lukes link, worked well for a while, then failed.
None of the parts are tough to swap, just a dirty job. align after install, i think the alignment cost me 50 bucks last time.
Flatbed24v
Feb 19, 2013 07:54 PM
donhov
Oct 12, 2007 11:44 AM
v8440
14
Sep 7, 2005 08:39 PM
Gordonville
Apr 18, 2005 09:45 AM
