Front Crank Seal for KDP ?
Old Jan 25, 2011 | 02:32 PM
Diesel_Power_2's Avatar
Question Red Threadlocker time to set?
Hi everyone,
I would like to know how long till red threadlocker set?
Thanks in advance.
Old Jan 25, 2011 | 10:27 PM
cj360trider's Avatar
i think its less than an hour. what are you threadlocking?
Old Jan 26, 2011 | 08:27 AM
cromulius's Avatar
If the gear cover seal has the red silicone on it like mine did you want no locker. In very small letters mine said install dry as also stated by the cummins parts man and an article I found.
Old Jan 26, 2011 | 08:40 AM
Hi,
Yes it is the gear cover seal and I think the dry install refers to not putting any oil or grease on the teflon inner part of the seal. I put the threadlocker on the outer dia. as per instructions. Hope that is right as it is done deal now. 1 hour dry time or so. Thanks cj360trider for the info.
Old Jan 26, 2011 | 02:08 PM
Tate's Avatar
I've never put any sealant on the OD of the seal, and its never leaked.
Old Jan 26, 2011 | 07:08 PM
i guess the sealer is kind of his "insurance policy" against a leak. usually unless i need to seal threads if im installing a metal bolt into iron or steel i ding the threads on the bolt just slightly so it acts like a lock bolt. thats what i did with my KDP tab bolt. but if its a steel bolt into aluminum definitely i use threadlocker
Rimcrew
Aug 19, 2012 01:04 PM
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Mar 6, 2011 01:09 AM
92smokin blacky
Feb 28, 2011 02:36 PM
dieseldave95
May 1, 2009 04:53 PM
