ford 10w 30 diesel oil???? yes or no for my 12v?
ok, kinda a newbie question, but im looking for a non synthetic oil i can use for my 12v to help with cold start oil pressure and all that fun stuff...... well i work at a ford dealer here in NH and apparently the diesel guys use a 10w 30 diesel oil.....
is this something i can also use for my truck??? use it in the winter only???
my cost per quart is $3.13, is this good/ bad or on par?
is there anything out their in the 5w or 10w variety that is cheaper/still of good quality??
how much oil does my truck take 12 qts?? and yes im still very new to my 12v, but im loving every minute of it so far
and PLEASE dont turn this into an oil war edited by admin
Not like it's a huge difference, but that sounds reasonably more than the ~9 bucks I spend per gallon of Rotella. It takes right around 12 quarts of oil. I throw 11 in and start it, let it idle for 5 minutes, then kill her and check a few minutes later. Same way for mine and my dads truck and both end up taking about another 1/2 quart to quart.
What do you have against 15w from Rotella? I don't think I've ever really seen anyone have an issue with cold starts on diesel's with ANY of the common brands.
Shawn
Shawn
well normally i cna count to five (warm startup) and have oil pressure at the 5 second mark, when i start my truck on some of these 20deg mornings, i dont see oil pressure till about 15 seconds..... i might be a little skittish b/c im soooooooo used to gas vehicles and the anti drain back oil system, and instant oil pressure upon start up.
my bigger concern is winter hasnt really hit around her yet and i worry its gonna get worse when it gets colder - we normally have spells in jan/feb of couple weeks in a row of 10 below or better and im not able to plug my truck in all the time, like when i leave work in the evening, and im going to be getting called in to go plowing late nights too............ i just dont want to screw anything up in my nice "new" 12v......
ill prob try the ford oil next oil change...... right now ive got the rotella 15/40, so i will do my first oil change with that, but i think ill give the ford stuff a shot unless there is some other 5w or 10w that i should try
thanks for the replies you guys
i'm in fryeburg maine not to far away from you, i have a 98 12v
i just switched to 0w-40 its a synthetic oil made by john deere for diesels, not cheap though at 5.37 a quart i think it was.
other thing you can do is walmart has 5w40 synthetic rotella for a decent price, only place i know of to get it.
who built your tranny, i'm gonna be building mine in the spring and would love to find someone near by to help out. send me a pm
ill have to check different walmarts, kuz the super store near me doesnt have any synthetic diesel oils....... ill keep an eye for the rotella 5w40 though......
and you sir have a PM
I just changed out my 15w-40 rotella for 10w-30.I will run this until around the end of March or so depending on the weather. I buy the 10w-30 from the UFA up here, as long as it is at least a CG rated oil it will be fine.The 10w-30 makes a heck of a difference at start up for the pressure coming up when it gets cold.
Plumb Wild
Mar 23, 2010 08:26 PM
