few simple questions
Old Feb 10, 2009 | 06:32 PM
97dodge12v's Avatar
i am gathering my final parts for my nv4500 swap, and i was just wondering for my input shaft on my t case, will i need the 29 spline shaft with the thin bearing or the thick bearing? the guys at trans parts warehouse said there are two styles? and my other question is are the bolts for my bell housing going to be the same as for the manual? where can i get flywheel bolts, and bolts for my pressure plate? thanks alot.
Old Feb 10, 2009 | 08:51 PM
Tate's Avatar
Cummins or Chrysler will have the flywheel bolts. Chrysler should have the pressure plate bolts, although you could probably just us a 10.9 or grade 8 bolt on that. I can find the thread size and pitch for you later if needed.
Old Feb 11, 2009 | 08:24 PM
97dodge12v's Avatar
okay thanks, and will i be able to use my starter from my auto?
Old Feb 11, 2009 | 09:36 PM
Tate's Avatar
Starter should work no problem. Your bellhousing bolts should also be fine, but if they aren't, they are just 3/8" bolts, easy enough to get shorter/longer bolts if needed.
Old Feb 12, 2009 | 12:57 PM
97dodge12v's Avatar
okay thanks for your help, where can i find a good starter rebuilt kit? sometimes mine will stick, or just click, then it will work. thanks.
any ideas on what input shaft i will need?
Old Feb 14, 2009 | 01:05 AM
marv h.'s Avatar
www.fostertruck.com has good starter parts and some other good stuff too. Whole starters if you want. I got starter contacts and fuel lines from them. Good outfit.
bansh-eman
15
Sep 21, 2009 11:11 AM
GoodoleBob
Sep 27, 2006 11:37 PM
dgibbs
Dec 22, 2005 09:19 PM
Dshiftff
Jun 7, 2005 05:58 PM
