Some simple 12V questions
Old Jun 4, 2005 | 07:10 PM
Dshiftff's Avatar
Looking for a 12V to bomb. Whats the deal with the pumps. HO/SO? 215 pump? One only come with a standard or something? Sorry for the basic q. But I didnt see a FAQ page anywhere... Thanks...
Old Jun 4, 2005 | 07:16 PM
dezlsmkr's Avatar
I have a 215 pump. I am pretty sure 98 12 valves stick and maybe autos all had 215's but i am not sure on that i may be wrong. I think most of all the 12 valves are good canidites like i said i have a 215 pump, but a set of delivery valves on a 175 pump or whatever they are exactly will bring you right up to speed with some injectors. I think it is just as easy to look on the engine data plate it will tell you what it is . ie 215, 175 ect. , but like i said i think the mojority of the 94 to 98 12 valves were pretty good canidites. Just my .02$
Old Jun 4, 2005 | 08:17 PM
squirlchasr919's Avatar
215 is the hp rating of the fuel pump, don't know if you knew that's what all the numbers were about.
From what I know 96-98 sticks all had the 215hp pump. The 98 quad cab, shortbed, manual is considered the "holy grail" of the 12v. If you want the extra cab space and a short bed and the 215hp pump that is the only year to get them. 96-98 autos are all 180hp pumps. If you are in doubt of the pump on the truck your looking at ask around on the site. The 215hp pumps all start with a certain combo of letters and numbers, and the 180hp pumps are different. Someone on here knows for sure.
Feel free to correct my on any of this guys, this is all info I picked up reading other posts on this site.
Old Jun 4, 2005 | 09:02 PM
infidel's Avatar
Engine evolution though the years here>
http://dodgeram.org/tech/dsl/Facts/epa_changes.htm
Old Jun 5, 2005 | 09:10 AM
Dshiftff's Avatar
Thanks for the info so far. with the 12V pump, They are not affected by lift pumps like the 24V's?
Old Jun 5, 2005 | 09:31 AM
dezlsmkr's Avatar
No, I never really hear anyone having problems with fuel pressure in the 12 valves. The p7100 pump is great. Besides i think a normal 12 valve holds like 30 psi as opposed to 12 psi in a 24 valve.
Old Jun 5, 2005 | 02:54 PM
bmoeller's Avatar
Fuel Pressure: 18-24 psi at idle, 28-36 at 2000 rpm with no load.
http://dodgeram.org/tech/dsl/Facts/96specs.html
Old Jun 5, 2005 | 02:58 PM
dezlsmkr's Avatar
Yea thats what i thought around 30.
Old Jun 7, 2005 | 02:02 AM
mr T's Avatar
dont even worry about the pump number differences with the 12 valves...so irrelevant till u hit really high HP...they're all awesome heck they're used on 8.3 cummins too
Old Jun 7, 2005 | 03:20 PM
Dshiftff's Avatar
thanks for all the info so far, other then the KDP and ol 53 block anything else? Can you tell if there is too much blowby without special equipment?
Old Jun 7, 2005 | 05:58 PM
bmoeller's Avatar
Not really, if it isn't noticeable. However you can make your own manometer pretty cheap. Probably less than $20-30.
Can't recall if it was here, or over on the TDR. Someone gave instructions on how to make one, and the measurements to figure out how much blow-by there is. I t was fairly recent, too. I'll try and dig it up for you, if you like.
There is always a litle bit, even with a new engine.
joem
Sep 16, 2011 07:03 PM
turbo6justin
Mar 17, 2011 10:22 AM
97dodge12v
Feb 14, 2009 01:05 AM
TxDiesel007
Nov 29, 2006 12:08 PM
dgibbs
Dec 22, 2005 09:19 PM
