fans
Old Jun 5, 2012 | 07:01 PM
96dodge2500's Avatar
fans
a few of my fan blades where bent on my engine .ive got a dodge v10 fan sitting around could i use this on my cummins ?
Old Jun 6, 2012 | 10:01 AM
infidel's Avatar
They look the same but I've never tried swapping them.
Beware of how the blades may have gotten bent;
usually from someone blocking off the flow from the radiator with cardboard for more heat but leaving the top, bottom or edges uncovered.
Old Jun 6, 2012 | 11:29 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Oh....I better check my blades...I have been using the cardboard thing for a few years..
Old Jun 6, 2012 | 11:32 AM
BILTIT's Avatar
I have never seen a bent blade due to using cardboard. We all use cardboard up here every year.
Old Jun 6, 2012 | 05:01 PM
patdaly's Avatar
I think Bill meant by leaving it unsupported, they sucked the cardboard into the spinning fan.........
Old Jun 6, 2012 | 05:24 PM
BILTIT's Avatar
Ah, cardboard does not go on fan side of radiator! lol.
Old Jun 6, 2012 | 10:08 PM
I was thinking the samething....
Old Jun 6, 2012 | 11:36 PM
075point9's Avatar
Have to use cardboard year round up here.
Kidding. We take it out for July and the first week of august.
Old Jun 7, 2012 | 02:44 PM
infidel's Avatar
The cardboard should cover the entire radiator except with a 8" hole cut of of the center so that the fan thermostat clutch doesn't lock the fan on.
If the cardboard doesn't cover all the way out to the edge of the radiator every time a fan blade passes from a place where there is airflow to no airflow the fan blade flexes a little till it bends and eventually breaks off.
Seen it happen several times.
Only effects fans with metal blades, plastic ones don't seem to mind the flexing.
Old Jun 7, 2012 | 04:36 PM
patdaly's Avatar
Hmm, glad you explained. I usually block most of the front, but never have all.
I will from now on with a 8" or so hole in the center.....
Old Jun 7, 2012 | 04:43 PM
BILTIT's Avatar
Hmmm, never seen or done that either. I do usually cut a hole in the middle though.
lvmknsmoke..
Apr 9, 2009 03:47 PM
Mattdrew
Sep 2, 2003 01:12 PM
AlpineRAM
Aug 6, 2003 02:06 AM
drecu
15
Mar 19, 2003 07:17 PM
Javaluva
Feb 10, 2003 07:56 PM
