external tranny filter
Old Oct 29, 2006 | 07:41 PM
garretch's Avatar
anyone use an external tranny filter? any recomendations? if you use an external one do you still need to use the internal one?
Old Oct 30, 2006 | 10:31 AM
infidel's Avatar
You still need to use an internal filter and service it. For this reason I don't feel an external filter is worth it.
Old Oct 30, 2006 | 08:02 PM
wilderness's Avatar
Spend the money on a complete flush and fill. Have that done once a year in between regular filter changes and you will be better off. I usually check for coupons for local shops because it is a little pricey. If you really want to add to your tranny get a bigger pan or cooler or both.
Old Oct 30, 2006 | 08:12 PM
vtailflyer's Avatar
I have an external spin on filter, I have heard to many horror stories of Converters spitting material out thru the coolers then into the pan where it can mess up the governer solenoid.
I mounted mine just below the coolant/tranny exchanger and also plumbed in a psi xmitter to monitor TC lock up PSI,
I use a basic PH8 filter size but stick with the pure one filters. If you do toast a TC at least most of the particles will be caught in the filter, and may not ruin the rest of the tranny...
Old Oct 31, 2006 | 05:45 AM
Greguw's Avatar
I did a external for the reason of running ful syn tranny fluid ... I will go 60 miles on my syn fluid , they say it's good for 100,000 but if I wanted to service the filter I would have to drop the pan to remover the filter and that defeats the whole purpose ...so now I can just unscrew the filter every 10,000 miles or so and put a new one on ...its great but was alot of work and if your not doing it for that purpose I wound not recomend it !
I did all my lines at the same time ...You can order all the fittings and hose's and even a 20 micron filter with bypass valve .
I even installed a gauge on the side of my housing so I could tell my trans pressure ...
Yes it is a little over kill but it worked for me ... I have 20,000 on my set-up .
Greg
Old Nov 7, 2006 | 09:57 PM
garretch's Avatar
Greg
where did you get the the fittings and bypass valve?
Old Nov 8, 2006 | 06:14 AM
Greguw's Avatar
Mcmaster Carr has everything ... I did it a little overkill ...Look under parker reuseable hydraulic hose fittings ...I used the 1/2 inch on everything and I also used hose swivel fittings and adapters ...Make sure you use the the hose thats is used with the fittings ...I think I used SAE 100r1 .
Like I said I got a littled carried away ... mine cost me around 300 bucks ... but it is very nice and I will never have to worry about it !
When you do your connection to the tranny just use 1/4 npt ...some guys have a problem and will not agree with that ...it's fine I used 1/4 npt in the front and rear tranny and I have never had a problem !
Greg
plug ugly
Jan 21, 2010 03:39 PM
grey ghost
Oct 15, 2009 11:12 AM
Dennis
Dec 4, 2008 10:00 PM
kawi600
16
May 9, 2006 08:47 AM
Greguw
Nov 28, 2005 04:40 PM
