Need a part number for sending unit
Old Oct 25, 2006 | 06:28 AM
atthepark's Avatar
I need to replace the fuel level sending unit in my 1996 Ram 3500 4x4 and cant find a part number. Any help would be apprectiated.
Old Oct 25, 2006 | 07:16 AM
plow's Avatar
4897668af, 04897670ab, 4897669ab Here are some fuel level sending unit part numbers I can't remember which one is for your model. Here is a part number for a reman unit R4798671 module LE 14067003 it is for a 96.
Old Oct 25, 2006 | 09:41 AM
nivram's Avatar
Do you have to replace the whole unit?, or just the Float. There is a lot of backyard fixes out there to save some money.
My float was eroded away alittle on the sides and I decided to put some Epoxy on it and re-seal it. so far it is working. It might be that the contact surface is coated, and needs cleaning for good contact. Check the ohmm reading to check and see if this is working. Replace the hoses?
Marv.
Old Oct 25, 2006 | 10:45 AM
atthepark's Avatar
Not usre if it can be repaired
Thanks for the info...I'm not sure if it can be repaired, I havent taken it apart yet. It has been dead for a while and I am just fixing various things on the truck. In the process now of replacing a high pressure fuel line on cyl.#1 when I can find the part. I probably need to replace the fuel lines too and figured I would do it all at once.
Anthony
Old Oct 25, 2006 | 10:51 AM
nivram's Avatar
Anthony
Might be a bad connection on the tank. Lift the bed or- drop the tank. Its fun either way. Parts-Dealer, might try some of the other sources out there. Mopar for less etc.
Marv.
Old Nov 8, 2006 | 06:40 AM
atthepark's Avatar
part number as follows
I got the sending unit from the local dealer ($60) and the part number is 4797738 for 1996 CTD. Dont forget to get the gasket the goes under the locking ring on the top of the tank.
outlawscotty
Nov 3, 2009 11:07 PM
itr.#1446
Sep 2, 2008 08:04 AM
deaconn
May 7, 2008 07:39 PM
matty169
Oct 12, 2006 09:28 PM
Black Cloud
Sep 23, 2006 10:59 AM
