engine takes off on start-up!??
Old Dec 28, 2002 | 08:52 AM
Guy's Avatar
Guy
I have been working on an engine that has been sitting for years. My first headache was trying to get the engine oil primed. With your help, I conquered that obstacle. Now that I have oil pressure, I was ready to start the engine. After an afternoon of manually pumping up the fuel pressure, the motor started. Unfortunately, it ran as though I had the gas pedal nailed to the floor. Does anyone know what problems I should be looking for?? I have already checked the pedal linkages and they seem to operate fine. I was going to try to adjust the idle brake on the fuel pump. Any insight would be appreciated. Thanks. :'(
Old Dec 28, 2002 | 08:58 AM
BIG MIKE's Avatar
Re:engine takes off on start-up!??
<br> Guy, <br> Did the engine run at high rpm and shut itself down, or did you have to shut it down?<br> BIG MIKE ???
Old Dec 28, 2002 | 12:21 PM
97Dually's Avatar
A past exp with a diesel racing on startup was air in the fuel lines due to leaky return lines. Find'em, plug 'em. Give it another whirl. <br>By the way, the second time was the lift pump going and air came in that way too. Same symptom. Air!! &gt;<br><br>TJ
Old Jan 1, 2003 | 07:55 AM
BIG MIKE's Avatar
<br> Guy,<br> Have you found your problem with your engine start up speed? BIG MIKE ;D
heinzboz
Apr 25, 2009 10:16 PM
wcbcruzer
Feb 24, 2007 04:40 AM
samasaurus
Oct 11, 2006 12:58 PM
NaplesNole
15
Jan 23, 2006 12:45 PM
swamper303
Jan 28, 2004 04:25 PM
