takes off in overdrive
Old Oct 10, 2006 | 12:51 AM
samasaurus's Avatar
I recently bought a 98 12v with and automatic tranny. It has #5 fule plate and 370 injectors and a new rebuild on the tranny with an upgraded torque converter. It also has the waste gate blocked off. It is a goes through the gears ok but when it drops into overdrive it just takes off. Would like that power through all the gears. What is making it act this way. I know it is overfueling and i need to do some more upgrades and increase the timming. can any one tell me what might be going on?
Old Oct 10, 2006 | 09:45 AM
infidel's Avatar
Most likely your tranny is slipping until it hits overdrive, turning HP into heat rather than forward motion.
Old Oct 10, 2006 | 11:33 AM
scottsjeeprolet's Avatar
That kick that you are feeling is the Torque Converter locking.
Old Oct 10, 2006 | 02:59 PM
XLR8R's Avatar
Put a lockup switch in it for the TC.
Old Oct 11, 2006 | 12:14 AM
samasaurus's Avatar
how hard is it to put a torque converter switch. and how does it work? It is suppose to have a after market turque converter with 40% more lock up. Is there an adjustment to the tranny i can do?
Old Oct 11, 2006 | 09:27 AM
infidel's Avatar
Originally Posted by samasaurus
how hard is it to put a torque converter switch. and how does it work? It is suppose to have a after market torque converter with 40% more lock up. Is there an adjustment to the tranny i can do?
Very easy. Instructions here http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Old Oct 11, 2006 | 10:44 AM
samasaurus's Avatar
how will the truck run with the switch turned off?
Old Oct 11, 2006 | 12:58 PM
redstreak's Avatar
It will run the same as always. You'll just able to lock the converter in second gear. Is there an upgraded valvebody in also?? If not I'd be looking into doing something soon to keep your tranny intact.
heinzboz
Apr 25, 2009 10:16 PM
72demon440
Apr 27, 2007 10:45 PM
wcbcruzer
Feb 24, 2007 04:40 AM
Mostwanted
27
Jul 16, 2003 09:58 AM
Guy
Jan 1, 2003 07:55 AM
