Engine Break In
Old Aug 4, 2013 | 01:35 PM
Ironduke10's Avatar
Engine Break In
12 Valve rebuild performed. Looking for best recommendations for break-in.
Old Aug 4, 2013 | 01:43 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Take this with a grain of salt...Until other members post..
I heard,, to break them in...Do not baby them...But put them under load..To seat the rings and everything else...
We did this mistake to a MF tractor with a diesel Perkins...Dad babied the tractor and didn't force it to smoke and dig the cultivator in deep..
After a few hours...The tractor was giving problem...Problem was...He glazed the cylinder walls for not putting it under load...Landed up having to rebuild the motor..
Old Aug 4, 2013 | 01:51 PM
joem's Avatar
x2 on diesel dave's post, I started doing the hard break in and oil usage on every engine iv done it to is 100% zero, even single ring slipper piston dirt bikes.
http://www.mototuneusa.com/break_in_secrets.htm
Although my new 2013 VW diesel came from the factory with Snythtic oil in it so not sure how that's going to turn out.
Old Aug 4, 2013 | 04:19 PM
Ironduke10's Avatar
mototuneusa
Yes..I saw this earlier today as well. Thanks
Old Aug 4, 2013 | 04:43 PM
Ironduke10's Avatar
Keep your foot into it!
Yes...I heard to to vary the speed, but put a load on it.
Old Aug 4, 2013 | 08:05 PM
Tate's Avatar
A lot of performance guys do a 5-10 minute break in with no coolant in it. Seats the rings much faster. Don't go any longer than that as you'll overheat and wind up doing damage. Do a search on Comp-D, lots of info on it.
Old Aug 10, 2013 | 09:55 AM
Ironduke10's Avatar
Thanks
Old Aug 10, 2013 | 10:40 PM
joem's Avatar
hmm, I would never do that- you want to seat the rings not blow the spring tension out of them. Iv assembled them dry and fired em' up- wailed until normal opp temp and then full them full throttle for a few bursts but never ever without coolant.
New2Diesel
Feb 28, 2011 08:28 PM
J Lent
Oct 7, 2009 06:50 PM
Chip
14
Jun 21, 2009 03:59 AM
Red3quarter
Sep 6, 2008 11:56 PM
angleiron
Aug 12, 2003 07:45 AM
