Egts
Old Mar 22, 2006 | 08:27 PM
busted's Avatar
Egts
can someone tell me what a safe temp is? at times i hit a hill with no trialer and it will go to 900-950. running at 70 down the raod 600-850. now im going to las vagas saturday and im just thinking will it get hoter in the mountians. i have a 6# plate and striat pipe star wheel full forwourd.
Old Mar 22, 2006 | 08:30 PM
infidel's Avatar
Assuming your probe is pre turbo you can drive all day at 1200°.
Only exceed this for a short amount of time.
Willy91's Avatar
1250 max sustained temp. anything over that is ok as long as you limit to a few seconds.
Old Mar 22, 2006 | 08:38 PM
busted's Avatar
probe is preturbo. will this get hoter in the mountians. anything i can do to get the egts down just a little.
Old Mar 22, 2006 | 08:40 PM
busted's Avatar
truck has 320.000 on it with same on the turbo.
Old Mar 22, 2006 | 08:42 PM
infidel's Avatar
Put an egg in-between your foot and the skinny pedal.
Old Mar 22, 2006 | 08:48 PM
RCW's Avatar
RCW
The Cummins will handle 1250 degrees F, all day long as long as you have high quality oil and the engine is not equipped with the plastic piston cooler nozzles. If you have the plastic piston cooler nozzles, keep the EGT below 1100, or you will blow one loose and fry a piston. Cummins set the plastic equipped engines up OEM at a max of 950 degrees F on EGT, so keep that in mind.
Altitude has little to do with the EGT, but load pulling a grade does.
Old Mar 22, 2006 | 08:57 PM
busted's Avatar
i run rotela change it every 3k. my truck is a 95 motors never been touched. would that year have the plastic piston cooler nozzles?
Old Mar 22, 2006 | 10:47 PM
Dr. Evil's Avatar
RCW, I do know about the plastic oil squirters but without tearing down the engine and pulling pistons, how do you know whether or not you have plastic piston cooler nozzles? Shame on Cummins !
Old Mar 23, 2006 | 08:42 PM
bmoeller's Avatar
Read this-
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
Old Mar 23, 2006 | 09:24 PM
busted's Avatar
thanks read that FAQ page. i do need a bigger exaust to lower it to. thats next on the list. would like to with a 5inch from turbo back. will be going with a hybread hx35. any help this upgrade would be a big help.
NOTSTK
Aug 9, 2003 09:10 AM
doug
103
Jul 2, 2003 02:27 PM
thecatsfan
16
Jun 20, 2003 10:36 AM
cowpie
Jan 29, 2003 09:08 PM
1ST GEN.
Oct 19, 2002 08:45 AM
