Dry Bearing sound?
Old Aug 27, 2011 | 11:11 AM
Diesel_Power_2's Avatar
Question Dry Bearing sound?
Hi Everyone,
During my first real road trip in my new to me truck I started to hear a dry bearing sound when under load. The sound seemed to be coming from below about mid truck. Any ideas as to where it may have been coming from. I do not hear it when just traveling on normal city commutes.
Thanks for reading.
Old Aug 27, 2011 | 06:03 PM
gorms's Avatar
Have you noticed if it happens in all gears/speeds? I've noticed that the torque of the Cummins, especiall at lower rpms, seems to amplify any noises (gear rattle) that are already in the drivetrain under heavy load.
Old Aug 27, 2011 | 07:24 PM
Hi gorms,
I think I noticed it more in 4th gear as I was in 4th climbing some steeper terrain. I also noticed the truck kinda groan quite alot more than usual "hard to describe sound" , maybe that is normal as the Rockies air gets lean as well when climbing and it was very hot.A good test performance wise, was on fairly old Hwy 7 going towards Prince George has lots of different roads.
It is an older truck and I am still working on bugs in the steering but am making progress. I now need a good alignment after installing Lukes link for the track bar. I am hoping that will make alot of difference.
Thanks.
Old Aug 27, 2011 | 08:28 PM
cj360trider's Avatar
have you checked fluid levels in ur trans t case (if applicable) and diff?
Old Aug 27, 2011 | 08:36 PM
Yes fluids are ok.
Thanks
Old Aug 27, 2011 | 08:41 PM
do you have a 4wd or 2wd truck? if you have a 2 piece driveline id check the carrier bearing (AKA Center Support Bearing). That wud give you that dry bearing rough sound about mid vehicle like you are describing. like i said thats IF its a 2 piece driveline. i have a 4x4 and its a 1 piece
Old Aug 27, 2011 | 09:05 PM
Sorry it is a 4wd. I was looking under it today and I saw a large donut shaped
thing " bearing?" right where the drive shaft exits the tc <- I think it is the transfer case and heads towards the rear diff. That may be the dry bearing if so. I will have to go and look closer.
Thanks for the input.
Old Aug 27, 2011 | 09:58 PM
Tate's Avatar
Thats a balancer on the driveshaft. Since you have a reg cab, you have a one piece shaft, so no bearings in your driveline.
Old Aug 27, 2011 | 10:16 PM
Thanks Tate,
I just took a look and saw it is solid metal for sure. So maybe in the TCase or something else? I guess it will become louder in time maybe the rear end??
Thanks
bngcustoms
19
Jun 14, 2009 01:08 PM
Bigsmoke3500
Mar 20, 2008 12:04 PM
wadecool
Jan 12, 2007 11:39 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
