drums won't budge
Old Sep 5, 2004 | 11:55 PM
ARAcummins's Avatar
drums won't budge
So I go out and buy the gm wheel cyc today and go to put them on. Problem, can't get the drums to come off. I have soaked them in wd-40, beat on them, back the shoes all the way off. They won't move. Any ideas?
Heath
Old Sep 6, 2004 | 12:42 AM
zulusafari's Avatar
Check the thread on stuck rims. The procedure is this:
Put the rear on jack stands. Block front wheels. Remove rear tire(s). Put one or two lug nuts back on, loosely. Start truck. Run up to between 5 & 20 mph (general range I have read here). Slam on the brakes! Remove loosened drum.
They say it works for stuck rims, too, but I had to tap my rear rims off with a sledge hammer when I changed wheels/tires this last weekend.
Old Sep 6, 2004 | 08:13 AM
Geico266's Avatar
Make sure you put lug nuts on before you hit the brakes or you WILL be chasing the drum down the driveway. I sometimes have to use reverse and drive, but it works evertime! Good luck.
Old Sep 6, 2004 | 09:58 AM
ARAcummins's Avatar
Thanks, I'm going to try right now. Let you know how it goes later tonight. Heath
Old Sep 6, 2004 | 04:30 PM
ARAcummins's Avatar
Well worked great, just like you said popped right off. brakes work much better with the goofy gm parts , now if I could only get my pedal pressure to react a little quicker, more like my 04. Oh well. Thanks
Heath
Old Sep 6, 2004 | 10:42 PM
DZLPWR's Avatar
Okay fellas, ive tried the truck on jack stands and hitting brakes method at multiple speeds with no aval. Ive noticed that the wheels wont lock up over 10-15mph.
I know that if i do a rear brake adjustment that it lasts for a few days and feels like it needs adjusting again. Mabye I should do an adjustment right before trying to pop the drums off again? Help! I want to do the GM swap but cant get the drums off to even inspect the guts. TIA -Jake
Old Sep 7, 2004 | 05:41 AM
infidel's Avatar
Try using the parking brake rather than the pedal with the wheels off the ground and spinning, forward and reverse.
Old Sep 8, 2004 | 10:45 PM
Dr. Evil's Avatar
You're da man Infidel......great tip !
22george
Aug 21, 2011 04:25 PM
Dangousity
Mar 11, 2010 11:18 AM
benroberts3605
Aug 3, 2009 10:08 PM
materdiesel
Apr 18, 2007 06:14 PM
