drastic RPM increase once hot
Old May 14, 2007 | 11:22 AM
Grantjd's Avatar
Here are the symptoms:
Im having a drastic change in idle RPMS once my truck gets up to temperature. Until the truck gets to normal running temperature it will start and idle fine, and drive as normal.
After a few minutes of driving, it will begin to climb rpms at idle, while in gear. Idle(no throttle input) will pull the truck along, almost to 1500. In Nuetral or park, they will climb past 2500 and sustain. I checked the throttle linkage and it stays at the normal, fully closed position while this is all happening. You have to really stand on the brakes to get the truck to stop once its hot.
I had a bad stock injector and replaced it with another stock one, thinking it was the problem. I have recently replaced all the injectors with DDP stage IIs and have had the same problem.
Any ideas to a cause of this?
Its a 98 12v , 3kGSK and a 100 plate. Auto.
Old May 14, 2007 | 11:24 AM
signature600's Avatar
Sounds like the GSK isn't right
Chris
Old May 14, 2007 | 01:24 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
?????.......weird problem...You could try and install the stock springs back in and do another test...
Old May 14, 2007 | 01:53 PM
Grantjd's Avatar
Only concern i have with the GSK is that i just pulled a 1000+ mile trip without this problem, and i had the pump completely diassembled when i put the GSK in, so im positive that they are adjusted identical.
Old May 14, 2007 | 04:42 PM
Then its not the spring kit...I have a similar problem with my linkage jamming up.Not the linkage,but something in the pump itself(governor arm maybe binding).Few times had cruise control without the cruise on....Hope its nothing in the pump itself....Any ideas from the other guys on the site??
Old May 15, 2007 | 02:39 PM
dieseltim's Avatar
revs after warmed up
Just a thought, have you checked to see if you are getting oil from your turbo? Pull the output off the turbo (compressor side), and see if you have any oil going to the intercooler. It really sounds like it is getting fuel from somewhere, could be oil from the turbo. I had a 1.6 VW that tryed to run away because of oil from blow by, it was very worn out and would try to stay running even after shutting off the key.
Dieseltim
Old May 15, 2007 | 05:27 PM
mr T's Avatar
when this happens have u observed the motor? what happens to the linkage?...what is ur idle set to?
i think its the gsks...they need to be taken out and inspected and u need to double check that no parts were left behind during the installation...its a simple motor...its not elctronically fuel injected...it can only be a couple of things
Old May 15, 2007 | 06:56 PM
Grantjd's Avatar
i checked out the linkage while the RPMS were climbing. It stayed put, as normal. 'normal' being ~850 or so. It sounds like i should yank the GSKs out and reinstall them to eliminate that possibility.
Old May 15, 2007 | 07:10 PM
mr T's Avatar
yeah I'd do that...u may have forgotten a shim in there...also when's the last time ur valves were adjusted?
folsom_blues
23
Aug 28, 2011 11:23 PM
duallydave
Aug 7, 2005 09:38 PM
killfast1
Jun 9, 2004 11:31 AM
kthornton
17
May 17, 2004 01:28 PM
fishin fever
Feb 22, 2004 08:32 PM
