does a third gen. ex. manifold fit a 12 valve?
Old Dec 28, 2009 | 09:03 PM
grail4life's Avatar
im in the process of putting a he351ve on my 12 valve and found a 3rd gen. manifold for cheap. i was wondering if they would fit because it would be better than my present adapter flange...
Old Dec 29, 2009 | 08:13 AM
Old-stuff's Avatar
I have read that they have different shaped ports.
Old Dec 29, 2009 | 12:14 PM
WUnderwood's Avatar
12 valve-rectangle ports
Common Rail- round
Old Dec 29, 2009 | 06:24 PM
Skip H's Avatar
third gen exhaust mainfold
The third gen exhaust manifold will bolt up ok. need new bolts and needs a little port match on the upper and lower part of the port. Just radius it and don't touch the sides. Use 2 stock steel 12V manifold gaskets on each port.
I installed the 3dr gen ATS manifold on my 12V and it works good and no leaks.
HTH.
Old Dec 29, 2009 | 08:53 PM
grail4life's Avatar
so would i need to put longer studs in??? and would i have to take it to a machine shop or could i grind it myself???
how do u guys think it will work with the he351ve
Old Dec 30, 2009 | 08:11 AM
blackimpala's Avatar
Is there an advantage to using the 3G manifold? Does it cure the cracking and bolt shearing problem?
Floyd
Old Jan 1, 2010 | 04:10 AM
MiB's Avatar
MiB
The 3rd gen (5.9l) manifold does not fit on the turbo FYI
Old Jan 1, 2010 | 06:05 PM
grail4life's Avatar
i want to put the third gen manifold on because im using the he351ve
conchfarmer
17
Feb 13, 2008 04:51 PM
jeepinaround
Feb 21, 2007 09:18 AM
GR40RCapri
Nov 29, 2006 10:14 PM
Mike S.
Aug 2, 2006 08:10 AM
