does oil in bubbles absolutely mean blown head gasket
Old Feb 26, 2008 | 07:24 PM
dodge_kid9712's Avatar
does bubbles in oil absolutely mean blown head gasket
well i have bubbles in my oil when i check the oil right after shutting it off..but if i check it 2 or 3 minutes after shutting it off they are gone...there is no coolant loss or white smoke.no bubbles in coolant.is this just normal frothing of the oil as it moves around the motor...should i be too worried its rotella changed 2000 miles ago...it looks pretty black but not milky or chocolatey at all....just wondering if the bubbles right a few seconds after shutting it off could be normal because i have none of the other symptoms?
Old Feb 26, 2008 | 07:30 PM
Common's Avatar
First time I've heard of this.
I don't remember any bubbles though...
Old Feb 26, 2008 | 07:53 PM
izzwardo's Avatar
mine does the same ever since I've owned my 95. Done it for about a year and no problems
Old Feb 26, 2008 | 08:06 PM
sweet thanks for replying..i needed another opinion because i have never really checked my oil right a few seconds after shutting off and got worried..
Old Feb 26, 2008 | 08:28 PM
merr6267's Avatar
Yeah, mine has a few bubbles in it right after shutdown too. A friend's old Ford 6.9 had hella bubbles in his.
I don't think it's anything to worry about . . . unless of course you have other issues.
Take care,
Phill
Old Feb 26, 2008 | 08:42 PM
dieselman2300's Avatar
Its just from pressurizing the crankcase and the oil splashing around.
Take a quart of oil and shake it up, youll get bubbles.
Old Feb 27, 2008 | 11:04 AM
lgp9999's Avatar
The brand of oil is probably a contributing factor. When oils foam up and trap air they lose their effectiveness. A higher quality oil will be less prone to trapping air.
Old Feb 27, 2008 | 08:52 PM
Ronco95's Avatar
Is your oil level correct? If it is too high, it will hit rotating parts and cause overheating, aeration and other problems.
Ronnie
DaddyRabbit
Nov 22, 2015 12:52 PM
bobem12
15
Apr 16, 2008 08:24 PM
1-5-3-6-2-4
ABDTR #5
51
Apr 3, 2008 08:14 PM
cumminsdriver635
Sep 19, 2006 01:39 AM
