Dirty turbo!
Old Jun 12, 2006 | 07:42 PM
Ironstone's Avatar
Dirty turbo!
I was wonder if there is a way to clean your turbo? (I'm new to CTD) I didn't check my air filter for about a month and when I did I found that one side has been ripped out completely (cheap Fram filter). It must have been like this for a while because there is all kinds of fine dirt on the turbo. I held the veins still to keep it from turning and blew it out with an air wand but its still got alot of dirt caked to it. I wiped as much off as I could get. I just changed the oil a few days ago and wondered why the oil was so dirty know I know why. I have a WIX air filtered ordered and am just waiting for it to arrive, should be any time now. If anyone knows any other cleaning tricks I'd appreciate it. Maybe it doesnt even matter I really don't know, but I don't like it.
Old Jun 12, 2006 | 08:59 PM
DieselDaze's Avatar
Ive had a like issue on my truck caused by an over oiled K&N filter.
The best way to clean these is to remove the turbo and clean thoroughly.
Removal of the turbo keeps the dirt/debris from ending up in the engine.
If I read your post correctly, you blew compressed air into the turbo. If this is correct, all the dirt that was built up in the turbo is now headed for your engine.
However, it sounds like this has been going on for a while so you may want to consider a couple oil changes a to flush any/all the dirt that has been going past your air filter.
Only real way to tell is by having your oil analyzed and evaluate your silica count.
When cleaning my turbo, I used brake cleaner sprayed on a q-tip and scrubed the fins, housing and inlet tubes until clean.
Lots of time, q-tips and scrubbing.
Rich
Old Jun 12, 2006 | 09:17 PM
Ironstone's Avatar
Thanks Rich
Yeh I just did some hog wash and qtip thing.....oil changes are next. Looks like ill pull the turbo this weekend and have a look at the other side.
Old Jun 13, 2006 | 01:20 PM
cnvrt2cummins's Avatar
I would just say to take the compressor housing off I really think this can be done easily in chassis,I do not see the reason for takinf the turbo off.
Old Jun 13, 2006 | 01:28 PM
CSAGrey1's Avatar
I hate to hijack the thread but how much of an issue is getting the oil from an over-oiled filter on your turbo? I have noticed that the bottom of the air box is pretty oily since I re-oiled my AFE. I may have gone a little overboard
Old Jun 13, 2006 | 05:32 PM
GAmes's Avatar
I'm not getting the connection here. Dirt flowing thru the turbo would go into the intercooler. Some of that could make it's way to the intake manifold, then the cylinders causing excelerated wear in the cylinder, then out the exhaust where it might excelerate the wear of the hot side of the turbo. Where in the cycle does it get in the oil?
Old Jun 13, 2006 | 06:22 PM
infidel's Avatar
It gets past the rings and valves.
Old Jun 13, 2006 | 06:26 PM
GAmes's Avatar
Must be some pretty lousy rings and valve seals
Old Jun 13, 2006 | 10:57 PM
displacedtexan's Avatar
No engine has perfect seals around the rings and valves.
Especially one with 400k.
Old Jun 14, 2006 | 06:46 AM
DieselDaze's Avatar
Do a search for K&N or AFE.
You may also want to do a search for over oiled air filter.
In short, it can cause the turbo to fail if the turbo becomes oil coated from the excess oil off the filter. This oil coated turbo catches the dirt and becomes grime... causing wear on the turbo and eventually, failure.
Start a new thread if your search doesnt come up with the answers your looking for.
Thanks
Rich.
ratat98
Apr 23, 2006 06:21 PM
ArcticWolf
Aug 16, 2005 12:11 AM
wcbcruzer
Jul 26, 2005 11:34 PM
Jmac
Apr 7, 2005 08:37 PM
Jmac
Sep 2, 2004 04:18 AM
