different ways to adjust timing??
Old Oct 13, 2006 | 05:04 PM
mr T's Avatar
hey guys...i have read that there are lazy ways to bump the timing...withoutb ever using the dial indicator method...
the reason im asking is that when i had my timing done...my gear cover was greased right...and when i got the truck back i couldnt find any evidence that they had touched the timing gear cover since they're supposed to remove it right? anyways i noticed a chalk mark on my alternator..hmmm..and these guys were done in 20 min...i just drank a coffee around the corner
my timing is indeed advanced and truck runs great
anyone know these methods??
Old Oct 13, 2006 | 05:22 PM
MDMIKE's Avatar
You don't have to remove the entire cover, just the oil fill tube on the front of the cover. I'm not sure why you would have a mark on your alternator, though? Are you pretty confident in the work these guys do? Did they tell you they set it at 15.5 or are you guessing? You gotta be careful with the timing issue. I had a local shop that said "they knew where to set my timing". I believed them, then 6 months later I had a blown head gasket.
MIke
Old Oct 13, 2006 | 06:28 PM
Baja's Avatar
It sounds like what the shop did with mine, and I am not happy. Yeah, mine runs better too, but it is not correct. They removed the timing gear, moved it a bit and called it a day. They said that they know if they move it a certain amount it is good to go. The problem is that they never checked where it was, so how do they know how far to move it? Get it done correctly, not by a guess.
Old Oct 13, 2006 | 06:49 PM
TxDiesel007's Avatar
I had shops down here that would do the same thing
I took no chances, and had gunracer1 time my truck.. No problems since then.... Did it once, did it right, and am happy with the results...
Something is fishy if they were done in 20 mins only..
Rick
Old Oct 13, 2006 | 06:50 PM
CTD NUT's Avatar
Let me guess.....Turner did the timing? There is absolutely no way to verify timing without measuring the plunger depth. If this wasn't done you won't have a clue what the timing was set at.
Old Oct 13, 2006 | 07:40 PM
mr T's Avatar
yep Turner did it...super fast...no a finger print worth of evidence anywhere...don't u remember they're the same guys that wouldnt sell me the luke's links because "its better to get a job done right not just patch things up"...this timing thing has just been on my mind for a while...i had it done a while back..
Old Oct 13, 2006 | 09:56 PM
DL1221's Avatar
You shoud really check the timing to see where they left it at. Hopefully its somewhere close to where you want it and you won't have to do anything else, and hopefully it won't slip either. Look for loss of power and white smoke. I did my own and it took me only a few hours, its not exaclty 16 because I bumpped the gear a bit, but I measured it twice and it is about 15.8, which is close enough.
Old Oct 13, 2006 | 10:17 PM
mr T's Avatar
yeah they claim it to be at 15.5...i have nothing to compare that to except to the original timing I had..with the timing where it is now it really woke the truck up...I was just curious at these quickee methods to do timing...seems to be a few shops doing it by feel only
Old Oct 14, 2006 | 01:19 AM
mudn_1's Avatar
is there any way to time it youself any help would be greatly appreciated? maybe a website where i could find instuctions in english not all the certified mechanics ********
Old Oct 14, 2006 | 07:45 AM
JKM's Avatar
JKM
Dodgeram.org has a TSB on setting the timing, not too hard to do IMO , but you need some special tools.
Old Oct 14, 2006 | 09:40 AM
infidel's Avatar
http://dodgeram.info/tsb/1994/18-10-94a.htm
Svenne
Mar 18, 2015 05:05 AM
jhenson
Sep 8, 2012 10:37 PM
Fisherguy
29
Aug 6, 2009 12:45 PM
Dave88LX
Dec 8, 2006 02:53 PM
andyr354
Aug 15, 2006 11:05 AM
