difference between frame's.
Old Apr 23, 2011 | 10:26 AM
primal13's Avatar
hi ya'll,
i have a dumb question. what if any is the difference between the 1500 and 2500 frame's, and the 7700lbs and 8800lbs 2500's. i have heard that the 7700lbs and 1500 frame's are the same. i ask because i'm looking to do a frame up rebuild on my truck. i have a 98 12valve quad short bed 8800lbs 5speed 4x4. also would a 3500 frame work, and what would be the perk of going with the 1 ton frame.
thank ya in advance for the help.
Old Apr 24, 2011 | 05:47 PM
gozapper's Avatar
both 4x4 trucks?
Old Apr 24, 2011 | 07:26 PM
primal13's Avatar
yes there are both 4x4.
Old Apr 26, 2011 | 01:11 PM
jstone44720's Avatar
Interesting question.
Old Apr 26, 2011 | 06:48 PM
gozapper's Avatar
The frame shop told me they are the same 1500 thru 3500.
Others on here don't agree!
Measure all three and see. I did measure them and they seem to be the same. Difference could be the cross braces.
Old Apr 28, 2011 | 09:45 AM
primal13's Avatar
so of the brace's are different from by buddies 3500 to mine. but the frame also seem's thicker if i remember. he has a 97 dully hd, it's a hog.
Old Apr 28, 2011 | 10:44 PM
gozapper's Avatar
My friend that runs the frame shop has repaired, straighten, spliced frames togeather for over 30 years told that they were the same.
I have a 01 1/2 short bed quad that I was thinking about putting a cummins into, but have decided to go long bed for a camper possibility. I did measure t/2 ton and the he thickness and found them to be the same on the 1 ton dually. I am not sure about the cross braces.
You are working with 3/4 and 1 tons. There should be no problems.
Tom
Old Apr 29, 2011 | 06:23 PM
primal13's Avatar
thank ya very much.
Old Apr 29, 2011 | 11:03 PM
Tate's Avatar
Tom
I know looking at my sisters 98 1500 4x4 vs my 98 3500 4x2, my frame was quite a bit taller, and a bit wider at the front. I haven't compared it with my 98 2500 4x4, or the 96 light 2500 4x2. The 96 feels lighter just driving it around vs my 98 2500, but its a gasser too. Everything but my 3500 is a reg cab.
roxxx
Nov 19, 2021 03:07 PM
Tyheethan
Feb 25, 2009 12:12 PM
gts95
Aug 27, 2007 10:13 AM
95black2615
Dec 20, 2006 06:37 PM
ptgarcia
Sep 12, 2006 06:04 PM
