Did dodge offer a Short bed pre 98??
Old Dec 19, 2008 | 11:01 AM
mach2's Avatar
Did dodge offer a Short bed club cab pre 1998?? Kelly blue book says they did but i find that hard to believe Because i dont think i'ev ever seen one.
Thanks Bryce
Old Dec 19, 2008 | 11:16 AM
97crewcab's Avatar
I believe you could maybe get a 2500 with a 360 before 98 but no cummins or v10.
Old Dec 19, 2008 | 11:24 AM
mach2's Avatar
DANG IT!!!!!!!!! I really would like to have a short bed club cab 12v
Old Dec 19, 2008 | 11:50 AM
97crewcab's Avatar
You mean you don't want a quad cab? Just a extended cab short box?
Old Dec 19, 2008 | 12:26 PM
rattlerbob5.9's Avatar
YES
My 96 2wd ext cab 1/2 ton gasser is a short box with the sport package .
Old Dec 19, 2008 | 12:58 PM
'strokeThis_'07's Avatar
Just 1/2 tons had a shortbed before 98. In 98 they had BOTH a quad cab and club cab shortbed. So if you want the club/short, and a diesel, 98s the only year
Old Dec 19, 2008 | 01:39 PM
haloman's Avatar
X2 and good luck finding a club cab/shorty I think Quad/shorty is easier to find.
Old Dec 19, 2008 | 03:16 PM
JohnX's Avatar
Mine is a clubcab shortbox, but its a 98.
Old Dec 19, 2008 | 03:27 PM
haloman's Avatar
Pics?......
Old Dec 19, 2008 | 06:54 PM
infidel's Avatar
My neighbor has a '95 2500 short bed with a CTD.
I always kid him he bought it so he has an excuse not to work because nothing will fit in the back.
Old Dec 19, 2008 | 07:03 PM
JohnX's Avatar
Originally Posted by haloman
Pics?......
Ask and you shall receive...
Old Dec 19, 2008 | 07:52 PM
Johnx
How do you like those 330 injectors ?
I am running 300's in my 94 with 181 DV'S i sometimes wonder if i should have giver her a little more=the330's it runs good with the 300's and the stock plate .050 forward no smoke or heat problems and stock wh1c.
Old Dec 19, 2008 | 08:10 PM
JohnX's Avatar
Power is good, but a little hazey at idle, not much, just enough to notice. I did the injectors after the intake and exhaust and heat was NEVER an issue. However, since doing the 100 plate and the turbo it seems to run hotter at cruise, but full throttle blasts are not over 1200. I won't get a load behind it until new years weekend, then we'll see if shes too hot or not
BTW, being a CA truck, I believe my DV's are still 131's. Need to change them and bump the timing to 15*.
Old Dec 19, 2008 | 08:31 PM
John do you get any off idle stutter that is what usually happens with the 131 DV's and smooths out around 1700 or under heavy fueling it is a lot more noticeable when pulling a load.
My 96 truck has the Cali egr smog set up on it and i have been trying to find out if it also has the 131 DV's in the 180 pump.
No idle haze on my 94 and i set the timing on it at 16.5 so i guess i will stay with the 300's i also have the 4:10's like you.
Old Dec 20, 2008 | 07:48 PM
JohnX's Avatar
Haven't noticed any off idle problems, even when pulling 18k. Ditch that EGR intake runner....you won't believe how much it restricts the airway. My timing is still stock, and I am tempted to leave it there just to help preserve the head gasket.
