Determining Gear Ratio?
Old Oct 26, 2007 | 02:01 PM
DanHfmn's Avatar
I'm selling my 12v and I'm trying to find out what gear ratio is in the rear. It's a Dana 80, 3.5 axle ratio according to the sticker under the hood. But one of my buddies swears it's a 3.73 or 4.10 due to the speedo/tach. It's about 2100 rpm's at 70mph. Tires are 265/75/16's.
Old Oct 26, 2007 | 02:41 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
At 70MPH my RPM is at 2400.I have 4:10 gears.
Old Oct 26, 2007 | 03:28 PM
davejobes's Avatar
I believe this to be the case-Automatics have 3:55's & manuals had 4:10's! The only way this may be different, if a former owner changed the gears or the factory changed the truck specs in mid production. Ether way, you can jack the wheels off the ground, put the truck in neutral, put a mark on the driveshaft & a tire. Spin the tire 1 time around and count how many times the driveshaft spins. 3-1/2 times is 3:55 gears, 4 times is 4:10 gears!
Old Oct 26, 2007 | 03:30 PM
dieselfuelonly's Avatar
DTR question asker
Does your truck have an auto or a manual?
If it is a manual, you probably have 3.54s. That sounds about right.
A manual with 4.10s will turn... HIGH RPMs at 70MPH.
Old Oct 26, 2007 | 03:38 PM
DanHfmn's Avatar
It's a manual..thanks for the tips. I might try the jackstand idea to just narrow it down.
Old Oct 26, 2007 | 05:57 PM
Tate's Avatar
Those RPMs are right for 3.55s. You can get either gear ratios with any of the transmissions, not quite as rigid as with options as they are now.
Old Oct 26, 2007 | 07:15 PM
Box5's Avatar
with ur tires and a nv4500
3.54's
71 @ 2000rpm
4.10's
61 @ 2000rpm
So it sounds like u have 3.5's
Old Oct 28, 2007 | 10:48 AM
fschiola's Avatar
Have you looked for the tag attached to the diff cover? It will have the ratio on it.
Old Oct 29, 2007 | 10:43 AM
Baja's Avatar
If you can't find the ratio on the diff tag, call the dealer with your vin number. From that they can pull the build sheet on the computer and you can get ANY information you want. It will have all the details.
hopak
Mar 3, 2009 11:38 AM
bstiger
Aug 4, 2008 06:18 PM
ultramag
Dec 15, 2007 07:03 PM
JD730
Nov 27, 2006 05:54 AM
-Ross-
Jun 19, 2006 09:52 AM
