death wobble?
Old Apr 26, 2006 | 04:34 AM
running4bhs's Avatar
death wobble?
Could bad ball joints cause the death wobble? Also I am replacing my ball joints right now because they are bad, but would I be able to drive a little bit on them or is that a fix now thing? Thanks guys
Old Apr 27, 2006 | 07:37 AM
12VRoush's Avatar
I had a a really bad wobble i thought it was my front end also . (Balljoints,hubs,sway bars,etc.) But i found out it was my rear u joint on my driveshaft. If it has any slack in it at all it will cause the truck to wobble and shake at about 40+mph. Also your counterweights might have broke off your drive shaft or your drive shaft might be bent. Just check around there you might find it?.?.
Old Apr 27, 2006 | 08:05 PM
jabber's Avatar
To answer you question. No, balljoint will not cause death wabble.
Old Apr 27, 2006 | 08:26 PM
ds1rider's Avatar
Order a pizza, then type "death wobble" into search bar.
725Gus
Mar 6, 2014 09:49 AM
Trooperthorn
Nov 30, 2010 12:06 AM
Jezzhuntin
Apr 11, 2007 04:52 PM
smokindodge1996
Feb 13, 2004 08:54 PM
moneypit
Sep 23, 2003 06:06 PM
