Coolant gauge & idle problems
Old Jul 25, 2003 | 06:33 PM
stoneman's Avatar
Hello, I need some help with few problems
1. All of the sudden my coolant gauge has stopped fluctuating from 190 to 140 as is normal. It now reads bet 190 & 230 with no up & down movement. Checked coolant level & its fine. The coolant itself & the motor are not hot at all. I can put my finger in radiator. I did notice I cannot see any circulation of the coolant when cap is removed. What gives?
2. Also all the sudden my truck wants to die when I turn the air on & drop it it drive. It doesnt want to die when its in neutral or when on the hi way. This starts as soon as I turn the fan on. What gives
Old Jul 26, 2003 | 02:00 PM
stoneman's Avatar
Re:Coolant gauge & idle problems
fyi the motor wanting to die with ac on was due to too much refrigerant. dropped it from 70lbs to 40lbs and idle smooth now.<br>cb
Old Jul 26, 2003 | 03:44 PM
Smokee's Avatar
Sounds to me as if the t'stat is stuck closed, or almost closed.
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
Ridiculous
May 17, 2007 07:28 PM
popeyesides
Dec 6, 2004 03:43 PM
