Cold start/stall
Old Jan 17, 2006 | 08:24 AM
tmacie's Avatar
Cold start/stall
Ok so I have a little annoyance with my 94. If its colder than 15 degrees (or so) over night I have to hold the throttle open a little to get the truck to stay running. The block heater is on a timer for about 2hrs before I start the truck. If I don't hold the throttle the truck fires then dies. I thought timing would solve this but it didn't.
Thanks for the help,
Travis
Old Jan 17, 2006 | 08:35 AM
wana12v's Avatar
no timing actually makes this worse. my timing is at 16* and it got a little rougher to start as well. I have to do exactly what you do.
you should see my buddies truck with 22* start when its cold, talk about a smoke show.
Old Jan 17, 2006 | 09:51 AM
tmacie's Avatar
Interesting, I'll have to set the timer to come on earlier.....
Travis
Old Jan 17, 2006 | 12:16 PM
John Faughn's Avatar
I think you need 4 hrs on the block heater ,
Whats your RPM when the eng. is warm , should be 750-800 , if not adjust , are you using fuel injection cleaner?
Old Jan 17, 2006 | 12:41 PM
tmacie's Avatar
Yeah thats what i was thinking of bumping it to. RPM at idle and warm is right where it should be 750ish. I'm running power service anti gel (white bottle) and the blend of fuel is 60/40 sooo i think im safe from gelling. Once it warms up a hair (30 sec at 1k rpm) it will idle ok.
Travis
Old Jan 17, 2006 | 03:19 PM
JKM's Avatar
JKM
Mine starts right up at idle (no throttle) even when the temp gets down to -15, not plugged in.
It sounds like you may need to set your idle up , i set mine to 860 RPM in D, as per the CPL on my engine. In N id idles up to almost 1000 , but that doesn't bother me one bit in the winter.
Old Jan 17, 2006 | 07:55 PM
Fred Swanson's Avatar
I set the idle at 850 on manuals. I little higher for the autos. The key is to make sure the GSK isn't too tight, too. Hey, it's getting cold here, last night it was 32 at my house.
Old Jan 18, 2006 | 12:21 AM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
You might want to replace your overflow valve.
Andy
flyingd
17
Jul 11, 2017 11:13 AM
corn binder
Feb 11, 2011 09:06 PM
RockysInMyBlood
0
Jun 18, 2009 03:14 PM
brewerjohn
Aug 16, 2007 05:07 PM
JD730
Aug 2, 2005 11:33 AM
