clutch question
Old Oct 22, 2007 | 11:35 PM
a77ssii's Avatar
clutch question
The clutch in my truck has 177K on it and is on it's way out. I just can't bring myself to drop $800 on a South Bend. I know what it takes to make them and that's about an 800% markup. I found one at Carquest that's Kevlar lined with heavier springs in the plate for $300. Anyone used one? Don't really care about pedal pressure, before I had the Ram I drove a '77 Scout with mechanical linkage. Just don't want to have to spend the $600 having it put in (gravel drive and highs in the 50's now with snow) and have to do it all over again in 50K miles.
Old Oct 23, 2007 | 12:07 AM
ScottN's Avatar
I put the Luk Pro Gold in... so far, so good for 2 thousand k or so. No performance mods, though, yet - and I only plan to do mild mods.
Obviously, not the same as what you are looking at. I would strongly consider the Valair, it reviews very similar to the Southbend, but is less expensive.
I'd probably stay away from the generic/no-name clutches... what is the quality? Uncertain. As you said, installation is a real cost for you, so your basic cost is $900 or so, is it worth it to go up to $1200-1300 and know that you would not expect to have any problems? That's for you to decide...
Note that this puts you in a price range of buying a 13.25" upgrade that includes a bigger flywheel, and a stronger hub in the clutch - which I'm sure were in the clutch you spec'd from SB.
Compare apples to apples. If you get a good clutch for your expected uses, it should cost you a lot less in the long run, even if it is more upfront.
Old Oct 23, 2007 | 11:30 AM
Box5's Avatar
Might wanna check out Edit. THey have some good deals
Old Oct 23, 2007 | 02:25 PM
tbarbee1's Avatar
YOu will not regret the South Bend
Old Oct 23, 2007 | 02:28 PM
dodgezilla04's Avatar
my ofe rated at 450hp has held 540/1191ftlbs. and i am not nice to it.
I agree with troy
Old Oct 23, 2007 | 04:51 PM
lgp9999's Avatar
I've got 16k on mine. It drives like a stock clutch, too (except for the fact that it will not slip regardless of how you drive the truck).
Old Oct 23, 2007 | 10:26 PM
a77ssii's Avatar
Thanks guys I'll check out the Luk I know they have a good rep. I won't buy the South Bend simply because of the price, they are way too proud of it. I went shopping for a camper shell and they all fell around $800+, not worth it so hunted till I found a decent used one for a price I was willing to pay. Same actually with my truck, I don't think any truck is worth $45K+ so I got my '96 which actually took me 2 months to talk myself into spending the $$ on (while my wife kept tell me to buy it the whole time).
WACTD
Jul 25, 2006 11:41 AM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
