Chirping under the hood
Old Jul 9, 2009 | 11:54 AM
Brendan's Avatar
Recently I have noticed a chirping or squeaking coming from under the hood at idle, especially when it's colder out. I assume it has something to do with the belt, but I am not sure, could it just be loosening up a little?
Old Jul 9, 2009 | 02:10 PM
John_P's Avatar
Try taking your belt off and inspecting it. On the bottom, if you see cracks in the rubber ridges, you may want to replace the belt. When my belts get like that they will start squeaking also. There are other things that can cause the squeaks, but I would start there.
John_P
Old Jul 9, 2009 | 10:59 PM
Dr. Evil's Avatar
Get yourself a Goodyear Gatorback belt and the chirp will go away.
Old Jul 11, 2009 | 11:19 AM
Clayten's Avatar
DTR's Toad Wrangler
It is probably the belt tensioner. Take it off, then take off the pulley, put some oil and grease on the shaft. I have done this several times to mine. It stops the squeaking.
Old Jul 13, 2009 | 04:33 PM
Brendan's Avatar
Sounds like a new belt and some tensioner TLC and she'll be good to go! Thanks guys.
Old Jul 14, 2009 | 11:12 AM
kawi600's Avatar
I just replaced my tensioner. If you take tension off the belt with a 1/2 wrench you can rock the pulleys and inspect for play. In my case the tensioner bearing was on the way out.
Old Jul 15, 2009 | 01:53 PM
macattack_ga's Avatar
that took care of the chrip at shutdown. Mine's got a bit of a chirp with running. maybe the idler...
Old Jul 20, 2009 | 08:35 AM
I am getting that noise on my '96 CTD and I think it is the belt tensioner. I had this noise on my Dodge V-10 and changed the belt tensioner and it went away for another 100,000 miles. Once I ignored it for to long and it seized up shredded the belt and left me w/ no accesories on the side of the road at mid-night
arroyojim
Apr 6, 2006 08:41 PM
ciscohusker
19
Sep 11, 2005 12:51 PM
Gear Poet
Aug 21, 2005 11:20 AM
Dodgezilla
Feb 13, 2004 03:40 PM
