Checking for boost leaks..
Old Sep 12, 2006 | 12:20 AM
cumminsdriver635's Avatar
Well, as some of you know, I seem to have some spoolup problems with my truck. I built a pressure tester tonight, and pressurized it. I mainly spent most of my time trying to get leaks stopped on my tester , but I did manage to find a small leak where the boost line runs into the AFC housing, and I got that fixed in like 2 minutes. Im gonna try it again tomorrow in the day time so I can see what Im doin, but so far that is the only leak I could find. I have only been able to pressurize it to about 10psi so far, but that is really the only time I have problems with spoolup is from 0-10psi. Now, I did go out on a test drive after I got the small leak stopped, and it does hold more boost at light throttle/loads, and does seem to spool a little faster from a roll in 3rd or overdrive, but It is still a dog mashing it from a stop. But as of right now, my main questions are, can you hear a leak if it is in the AFC diaphram, and how much should I pressurize the system to, and how long should it hold it? thanks guys.
Eric
Old Sep 12, 2006 | 04:50 PM
oldsmokey97's Avatar
where are you pressurizing the system from???
I have been wanting to check mine for leaks by pressurizing also but have not come up with an idea of how to do it. How did ya do yours?
justagoodolboy
Sep 7, 2022 12:43 PM
abchoppers
Jan 26, 2011 05:38 AM
ctdnwakulla
Dec 6, 2008 11:56 AM
Ph4tty
May 4, 2007 06:17 PM
mr T
Apr 24, 2005 12:25 PM
